2 small holes at bottom of end can ..
#21
+1  ...  interesting
Good photo, thanks for putting that up.
I have wondered what the internal structure is like
That answers it nicely  :thumbup
And supports the idea of silicone sealant on the outside for older ones when that mild steel cap starts to go.
Good to see the insides
Your connector pipe on the left seems to be stainless steel, as far as I knew it was mild steel
Thanks Fazerrider  Smile
Always wondered what the inside looked like, but was too scared to hack mine up. hopefully if i get some firegum it will sort the job.
Do you think this would have any bearing on my mild vibration problem? at around 5k+ RPM.
@ Fazersharp. The inlet pipe seems to be a different kind of steel, almost no rust spots and a similar shiny appearance (where the black paint has fallen off) to the stainless of the can, but it's magnetic whereas the can isn't.
Silverlegacy: the slight vibration from the engine at 5-6k is just a feature. Best solution is to keep the engine speed up above it. :lol
(11-02-15, 02:57 PM)Fazerider link Wrote: Silverlegacy: the slight vibration from the engine at 5-6k is just a feature. Best solution is to keep the engine speed up above it. :lol
Ah i see, i think i might of been using feature of the bike a bit too much then, time to twist the throttle a little more.
Although i only really commute to work on it and not much road to open it up and mainly through town.
Thanks anyway, might find another way home tonight, after stopping off at halfords for Firegum
Some cheaper lower grade stainless is still magnetic, try it on your sink and you may find the bowl is not magnetic and yet the drainer is.
just curious fazer rider, does the left hand cone line up with the outlet hole at the end of the exhaust?
reason: sharp spike hammered straight down the length of the exhaust.
(13-02-15, 10:52 PM)Paulfzs link Wrote: just curious fazer rider, does the left hand cone line up with the outlet hole at the end of the exhaust?
Well, sort of. That is, the cone is central and so is the outlet, but the outlet pipe is at an angle so your "tuning" mod (if that's what you're hoping for) will have to go through the side of that pipe in order to stay central. Chances are that the force needed to drive a spike down there would end up ripping the welds apart, particularly the spot welds to the mesh. So you'd end up with a can full of mangled metal that sounds bad and performs worse. :lol
hmm, i suppose itd be worth a punt as standard exhausts are easy to come by, i knocked the hell out of the outlet and its made it louder but still not loud enough without changing it.
it did make it pull a little better but barely noticeable.
also what mesh? haha
on the outlet youve got the smaller tube in the middle all the gasses come out from, i cut out the outer ring around it, its welded to the next part down obviously but makes it sound a heck of a lot better and improves acceleration a little (barely noticeable)
2 holes on my 02 Fazer, they are for water to drain out but I never put water down the end of my exhaust  :b Mine does blow a little between the can and the pipe, more noticable in the winter due to the exhaust being visible but it is slight.
