Date: 11-05-26  Time: 19:21 pm
Author Topic: rev counter fault code  (Read 5728 times)
fletch
« on: 20 June 2012, 08:57:50 pm »
You've probably gone over this before,but i tried searching and couldn't find what i was looking for.Basicaly my rev counter is playing up with the ignition on everything seems fine.When i start up everything is fine for 5 seconds then the needle drops for a second then shoots up to 7k then starts working for 5 seconds then the cycle repeats i've checked the exup valve everything is free that end and i have not noticed any drop in performance.So for the love of god please help me it's driving me insane  :'(
mcyoungy
Re: rev counter fault code
« Reply #1 on: 20 June 2012, 09:22:02 pm »
Exup fault I think. Could be motor, cables or valve itself. Could be cables have stretched, valve may be sticking but the code is generated by the servo motor not being in the position it should be.
ghostbiker
« Reply #2 on: 20 June 2012, 09:48:26 pm »
If your 100% sure the exup valve is ok then its most likely badly adjusted cables. vevery rare its the motor itself.
but be aware the exup can look great when you take it apart then stick as you tighten up the bolts
follw the guide on pats page
fletch
« Reply #3 on: 20 June 2012, 10:00:58 pm »
i took the pulley off an turned the valve by hand next question how do you adjust the cables? i was in belgium riding in terential rain when it first happened i suppose somethin could've slipped
know your limitations
« Reply #4 on: 21 June 2012, 03:29:58 am »
This the link to "Pat's page" mentioned above. All you'll ever need to know is here.....
cartestsoftware.com/fz1/exupmaintenance.html
It may look daunting first go but follow this to the letter and you'll be sorted in no time.
fletch
« Reply #5 on: 21 June 2012, 03:22:11 pm »
it looks simple enough thanks for the help
fletch
« Reply #6 on: 27 June 2012, 11:12:13 pm »
problem solved it was the servo motor stuck a quick srip and lube did the trick thanks for your help  :D :D :D :D
