Date:
11-05-26
Time:
19:21 pm
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
rev counter fault code
« previous
next »
Print
Pages: [
Author
Topic: rev counter fault code (Read 5727 times)
fletch
Naughty Corner
CBT Wobbler
on:
20 June 2012, 08:57:50 pm »
You've probably gone over this before,but i tried searching and couldn't find what i was looking for.Basicaly my rev counter is playing up with the ignition on everything seems fine.When i start up everything is fine for 5 seconds then the needle drops for a second then shoots up to 7k then starts working for 5 seconds then the cycle repeats i've checked the exup valve everything is free that end and i have not noticed any drop in performance.So for the love of god please help me it's driving me insane
Logged
mcyoungy
Club Racer
Re: rev counter fault code
Reply #1 on:
20 June 2012, 09:22:02 pm »
Exup fault I think. Could be motor, cables or valve itself. Could be cables have stretched, valve may be sticking but the code is generated by the servo motor not being in the position it should be.
Logged
ghostbiker
GP Hero
Reply #2 on:
20 June 2012, 09:48:26 pm »
If your 100% sure the exup valve is ok then its most likely badly adjusted cables. vevery rare its the motor itself.
but be aware the exup can look great when you take it apart then stick as you tighten up the bolts
follw the guide on pats page
Logged
fletch
Naughty Corner
CBT Wobbler
Reply #3 on:
20 June 2012, 10:00:58 pm »
i took the pulley off an turned the valve by hand next question how do you adjust the cables? i was in belgium riding in terential rain when it first happened i suppose somethin could've slipped
Logged
know your limitations
Naughty Corner
Weekend Warrior
Reply #4 on:
21 June 2012, 03:29:58 am »
This the link to "Pat's page" mentioned above. All you'll ever need to know is here.....
cartestsoftware.com/fz1/exupmaintenance.html
It may look daunting first go but follow this to the letter and you'll be sorted in no time.
Logged
fletch
Naughty Corner
CBT Wobbler
Reply #5 on:
21 June 2012, 03:22:11 pm »
it looks simple enough thanks for the help
Logged
fletch
Naughty Corner
CBT Wobbler
Reply #6 on:
27 June 2012, 11:12:13 pm »
problem solved it was the servo motor stuck a quick srip and lube did the trick thanks for your help
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
