Scottoiler gone bad?
My old one gave up after over a decade.
New one stopped working after about one year.
My friend's boss had his die also.
Grey ones both.
Anyone else experienced this?
(I bought mine from German Amazon, so no use in trying to get a warranty - in Serbia, at that time, no one was importing them)
[Image: scottoiler.jpg]
I've seen a few units fail over the years, nearly all of them was down to o ring seals failing. That was caused by owners using used car oil that had additives/fuel in it, that attacked the o rings.
Contact Scott they're very helpful, possibly all you need is to replace one or more said I rings.
Later
If it's not the seals, check the vacuum take-offs from the cylinders.
Mine stopped working when one of the pipes developed a split and I had to put it onto a different pipe.
If that doesn't work, I've got a spare Yellow vSystem one here that you can have for a few quid (bought it as a replacement before I realised what the problem was... Sad )
I'm in Serbia.
No official import or support.
I did check the vacuum on the carb and it is working fine - the main unit is broken apparently (the Scottoiler itself that is).
Since it's not the only new unit in my city to fail, I do not plan to go and buy another one.
On the bright side: I don't have time to ride much, so chain mileage is the least of my problems at the moment. The silver lining.
(30-08-25, 12:59 PM)Slaninar Wrote: I'm in Serbia.
Still contact them they should still help you.
Later
I've tried priming one more time, with new hoses and connections - hasn't worked.
Contacted Scottoiler and it seems they will be mailing me a new oiler.
If that goes through, it's more than fair - amazing!
(01-09-25, 11:50 AM)Slaninar Wrote: Contacted Scottoiler and it seems they will be mailing me a new oiler.
If the internal O rings or their mating surfaces are worn you'll not get a vacuum.  Scott are a good company with a quality product, sadly many are fitted and set up badly, especially by dealers.    This gives rise to all manner of issues and much bad press.
Installed and set correctly they work flawlessly for many years.
I've got customers that I fitted them to over 20yrs ago still working, Busas, ZX1200Rs, Blackbirds, Gixers, R1s, Blades, FZS, you name it.  All get 25k plus from their chains with little adjustment required.  One of the Busas got 38k from it's chain.  It was the front sprocket that buggered the chain in the end.
Glad you got it sorted mate  Thumbup
Later
I gave up using them after nearly 2 decades of trying. Being a 365 rider in allsorts if weather meant I had to keep adjusting it. Ended up with a dry chain or puddles on the floor.
I ended up making my own electronic chain oiler a few years ago, and it's the most reliable one I've ever used. Made a few for
mates, and put best part of 30k on them.
And the best bit is, they cost less than £20 to make. ?
[Image: 850481.png]
(03-09-25, 08:21 AM)Gnasher Wrote: If the internal O rings or their mating surfaces are worn you'll not get a vacuum.  Scott are a good company with a quality product, sadly many are fitted and set up badly, especially by dealers.    This gives rise to all manner of issues and much bad press.
Still not sorted out.  Smile
Apparently, the package returned.
I had ordered to my warehouse in Germany, when I bought it originaly (on German Amazon.de).
It arrived there first.
So, for the replacement shipping address, I asked if they could ship there, and sent precise info ("Name: company-name; Last-name: my-mailbox-code; Address: xxx; Contact phone in Germany:... etc.).
Turns out they sent the package to my name (not the Name&Last-name I sent in the instructions), so the package came back (first time I've had that hapen after dozens of packages there over the years).
Now Scottoiler wants me to pay for a tracked package.
I don't plan to pay for that. Based on the two units in my city (mine and friends') - it is a very small sample but I would rather not add any more money or time to what does not look too promising.
It used to be awesome. Now I'll probably switch to more ordinary ways of lubing the chain - with all the pros and cons of that.
Unfortunate, but that's life, modern market, and life in Serbia.  Smile
This may be an isolated unfortunate case - but it is what it is.
(27-10-25, 02:38 PM)Slaninar Wrote: Still not sorted out.  Smile
Do you live in Germany or Serbia?
(27-10-25, 02:38 PM)Slaninar Wrote: It arrived there first.
Post arrives only once, did someone else forward it on?
(27-10-25, 02:38 PM)Slaninar Wrote: So, for the replacement shipping address, I asked if they could ship there, and sent precise info ("Name: company-name; Last-name: my-mailbox-code; Address: xxx; Contact phone in Germany:... etc.).
If the package was in your name and sent to the correct address as you mentioned who rejected it?  It won't be anything to do with Scott Oil they sent it someone in Germany rejected it.
(27-10-25, 02:38 PM)Slaninar Wrote: Now Scottoiler wants me to pay for a tracked package.  I don't plan to pay for that. Based on the two units in my city (mine and friends') - it is a very small sample but I would rather not add any more money or time to what does not look too promising.
You can't blame Scott oil for someone returning the package, they've already paid for it, why should they pay again for someone not accepting it.  As mentioned your oiler is damaged and they offered to replace it.  As you said Amazing service.  You've decided not to continue so what are you complaining about?  If the postage is less then a new unit you're ahead it's a no brainer.
(27-10-25, 02:38 PM)Slaninar Wrote: It used to be awesome. Now I'll probably switch to more ordinary ways of lubing the chain - with all the pros and cons of that.
It still is, you've decided to give up on it.
(27-10-25, 02:38 PM)Slaninar Wrote: Unfortunate, but that's life, modern market, and life in Serbia.  Smile
That's were your issues lies not with Scott oil.
Later
My previous reply is gone.
Anyway, fair to note: Scottoiler is sending the unit again, this time addressed correctly.
Great persistence and professionalism.
The first package could not be delivered because it's a warehouse, not my home, and without the proper addressee (if that's the right term), no one can know who the package is for. Scottoiler fixed that now, during the re-send, so I hope the package will arrive.
The warehouse serves hundreds if not more people to bring stuff from Germany to Serbia and sort out the papers - shipments as an individual, directly, can be a problem and are often charged more than the order is worth (our customs are very creative).
So, this is not perfect, but it's the only thing that actually works in practice.
I've had dozens of packages from the EU and US delivered over the years, from different senders, without any problems.
A friend had one or two packages lost over the past decade and hundreds of orders, but that was still claimed - just not delivered to him.
Hoping to receive the new unit and see it last at least half as long as the first one.
You hit the nail on the head there Gnasher, poorly fitted ones are the biggest issue . The vacuum take off piece can crack over time and would need to be checked if bike is not running right and has a Scottoiler fitted.. i always keep a few as spares for that reason.
No unit.
It is now 4th month of going back-and-forth.
I originally purchased from an address in Germany (a "mass" warehouse that transports stuff to Serbia to each particular customer based on user ID). That is the exact address I told the Scottoiler customer support to ship the replacement unit to.
They sent the package, and the package returned. They asked me to pay for a tracked package, stating that they must "charge for tracked shipping to ensure that it arrives correctly."
It turned out they got the shipping recipient name wrong, so the warehouse didn't know who it was for, and the package returned. Once we concluded that, Scottoiler sent the package again, without insisting on my paying for tracked shipping.
However, the re-sent package returned again. This time German customs required the missing info:
- A commercial invoice.
- Correct value declaration.
- Proper export CN22/CN23 documentation.
So, without that info provided by the sender, the shipment has been returned to sender.
Now, customer support wants me to pay for a tracked shipment.
It has been almost 100 days now. I spent quite some time and energy trying to figure out the shipment problem causes and find a way to make it work - so the Scottoiler can do what's right (if they want to).
As I stated in my last email, I am not willing to invest more money. I paid for the product, it broke after almost no use (first trip after having installed it), and I can't get a replacement to the address where I had ordered the product originally (Serbian customs are pure evil and I import everything using the above-noted company warehouse in Germany).
Important info is that I had ordered the "original" (yellow) model on Amazon website, but I received a new ("updated / upgraded") model "with no extra charge." That was presented as an upgrade at no extra charge, but in hindsight, it looks differently.
Since another Scottoiler in my very city had the same short lifetime, I am suspecting that production quality has been reduced. Based on this customer support experience, I will not be buying or recommending this product anymore. I used to swear by it - but that was the old model that is apparently discontinued.
From my point of view, I did the right thing and gave Scottoiler every chance to do the right thing in return.
I still have the Yellow one here somewhere if you want it for a few quid plus shipping.
(09-12-25, 12:04 AM)Grahamm Wrote: I still have the Yellow one here somewhere if you want it for a few quid plus shipping.
Thank you. That sounds awesome.
Scottoiler used to have a local representative (who also did a lot of bike touring).
Now that shop has closed, and AFAIK there is no other local alternative.
There seems to be some problem with shipping, customs - apparently that is stricter and crazier than it used to be.
According to the latest email, Scottoiler will try one more time, perhaps directly to my address in Serbia (and if that makes it, it is a gamble to see how much the customs will try to charge me for the package - that could easily be $100 - could be zero, but it's a gamble).
Risk with private person to private person packages is smaller but still exists.
While Germans seem to have tightened policy for packages from outside the EU (about a year ago I ordered a $300 HDD from the US with no problems, just provided a receipt to prove the price I actually paid for the product+shipping - now this procedure with Scottoiler seems to be different).
I'll wait to see how this third shipping attempt plays out and if that fails, see what to do next (and if your offer is still available).
Ok, let me know if/ when you're still interested and I'll dig it out.
A new core unit has arrived. Same problem. What am I doing wrong (note that the setup is the same as it was with the first unit that worked)?
Short video of the setup:
https://www.youtube.com/watch?v=EfLt1SEZq_0
Edit:
Forgot to prime it. LOL.
Looks good now - hopefully will test it on the road in the spring.
