22-07-25, 09:16 AM
Hi Does anyone know if it's ok to use 3ohm dynatek coils on an fzs1000 ? TIA
Ignition coils
22-07-25, 09:16 AM
23-07-25, 01:08 PM
I assume those Dyna coils are single "coil-on-plug" types?
Well, it becomes marginal. The original coils have 2.2 ohms and are dual/wasted-spark type. You would have to take 2 Dynas in parallel as replacement. That lowers the effective ohmic value down to 1.5 ohm and gives about 30% increase in current. That's a lot of additional load to the output driver.. I did some research on that topic and documented it here: http://cvieth.bplaced.net/motorrad_zuendung.html (sorry for german..) My solution was to add an external driver circuitry, to be on the save side. (23-07-25, 01:08 PM)schlumpf Wrote: I assume those Dyna coils are single "coil-on-plug" types? They are twin coils Dyna Dc1-1 ? (23-07-25, 01:58 PM)Woodzey80 Wrote:(23-07-25, 01:08 PM)schlumpf Wrote: I assume those Dyna coils are single "coil-on-plug" types?
23-07-25, 05:02 PM
Ah okay, even better. The ECU-box is electrically save with those.
Next questiosn (for neerds) would be the inductance value. That also defines how much energy can be stored for the spark. I assume it's in the same ballpark as the original. Is it to replace a bad original coil? Or do you aim for a better spark with more energy? If the later then you should also consider to improve the overall power cabeling. Some significant voltage gets lost there.
23-07-25, 05:40 PM
(23-07-25, 05:02 PM)schlumpf Wrote: Ah okay, even better. The ECU-box is electrically save with those. Yeah to replace faulty originals, second hand ones are obviously showing there age now & don't want to take a chance. The new Chinese ones seem even worse !! I will look into the inductance value, my main concern with them being 3ohm would they be ok with the cdi unit. |
« Next Oldest | Next Newest »
