15-10-24, 09:07 AM
Hi all, looking to tap into the wealth of knowledge that is the forum.
2001 model FZS600
Been off the road road for nearly nearly a year due to many issues.
Checking yesterday I have lost supply to the side light, rear light it not working either.
Headlights have power supply dip and main (although bike has previously linked the headlights so as both sides illuminate)
Brake lights work both front and rear BUT this also illuminates the number plate light?
Indicators work fine
Dash lights work fine
Rear light not illuminating, number plate light not illuminating.
Any obvious fuses or places to check?
Only things I have done is replace the indicator relay to fit LED indicators and replaced the dash lights with leds, the headlights are disconnected as the faring is off.
The number plat light coming on with the brake light sounds like a bad or crossed earth , but short of stripping off to look at the connectors on the rear light any easy routes to check? the main fuse box looks ok the fuses in there are all fine but do not seem to cover the side lights or rear light
2001 model FZS600
