Reg Rec Wiring
Hello!
The reg/rec on my fzs 600 2003 has melted the connectors! It also has been rewired so a standard oem rec/reg wont fit any more.
Few questions!
  1. Does the order of the white wires matter when connecting to the reg/rec ?
  2. Could i just hard wire it with my new reg/rec ?
  3. If no on number 2, what connector do i need and any advice / tutorial on how to fit the wires into the connector ?
Thanks all!
1) No
2) Yes, but good, clean soldered joints, well insulated from each other.
3) If you are buying a new RR, I believe that you can unclip the spades from the connector plug and purchase a replacement male and female connector for both ends. I have used this company before https://www.vehiclewiringproducts.co.uk/
45a Anderson Power Poles are the best solution and is what I used back in 2017. Neat finish and can be disconnected easier than the original was before burning out
(30-09-22, 03:16 PM)unfazed link Wrote: 45a Anderson Power Poles are the best solution and is what I used back in 2017. Neat finish and can be disconnected easier than the original was before burning out
How often do you need to disconnect it?
Thanks for the replies!
I’m just going to hard wire it, been advised by a mechanic friend that crimping it would be the best solution so will do that.
Can’t be bothered with adding new connections to faffy and could melt again!
Thanks all
(01-10-22, 07:04 AM)midden link Wrote: [quote author=unfazed link=topic=27514.msg330369#msg330369 date=1664547366]
You would only need to have to do it once
