Crash pads/bars
What's everybody using for prtection?
Yamaha Frame Sliders
Be careful about other styles that bolt directly to the frame instead of having a "break-away" bracket on them, because they can transmit the shock of a fall directly into the frame and could crack it!
R&G front spindle and frame crash bungs, and "ebay special" rear spindle bungs.
(14-03-21, 01:39 AM)Grahamm link Wrote: Be careful about other styles that bolt directly to the frame instead of having a "break-away" bracket on them, because they can transmit the shock of a fall directly into the frame and could crack it!
Always go for a 3 point mounting like this https://sw-motech.com/en/products/protec...011720.htm they may not look as neat as a crash mushroom, but as mentioned they won't rip/tear, fracture and/or and I've seen this many times, bent into the engine casing, writing them off.
Later
Just got R&G sliders and bar ends on mine. Even tested them out, check it out here: https://www.instagram.com/p/BuHQ8CUne5f/
Between them and top box, it all held up well. Tiny scrape to engine cover, bust peg and bottom of side stand ground down a spot. Either way, they did their job and saved a lot worse damage.
(16-03-21, 10:48 PM)Arfa link Wrote: Even tested them out, check it out here
Ouch  :eek
Glad it wasn't any worse and there wasn't traffic coming up fast behind you...
