So as I needed some wheels bearing for the FZ1 I thought I would check if any of the spare bearings I still have for my FZS would fit, and some of them do -
I personally prefer to source all my bearings/seals from Marksman Industrial, as you can put in the Yamaha (or Suzuki, Honda etc) and it will find your bearing/seal for you. They also have 'bearing kits' for both bikes, which can save you a chunk of change compared to going oem or even wemoto -
- FZ1 - fowlers - https://www.fowlersparts.co.uk/parts/639...rear-wheel
- FZS - fowlers - https://www.fowlersparts.co.uk/parts/418...rear-wheel
- 2x bearing (ball)- 93306-00420
- 2x seal - 93106-28043
- 1x bearing (ball)- 93306-20531
- 1x seal - 93106-40013
- 1x R/H bearing (ball) - 93306-20531 - bearing number 62-28-2-RS
- 1x R/H seal - 93106-40013 - seal number 40-58-7
- 1x L/H bearing (roller) - 93317-33590 - bearing number 35-20-2-RS
- 1x R/H bearing (ball) - FZS - 93306-07806 - bearing number 62-28-2-RS (so same as FZ1)
- 1x R/H seal - 93106-35042 - seal number 35-52-8
- 1x L/H bearing (roller) - 93317-43580 - bearing number 35-20-2 RS (so same as FZ1)
