Gen1/2 Fazer 1000: Common maintenance & tasks
As we have a few thread for common tasks that get repeated threads, I figured it would make sense to create a sticky with links to all of these threads. I will update this OP as I go, so welcome suggested threads to be added to this sticky.
[size=1.35em]Gen1[/size]
  • General techniques: Cleaning brake pistons - link
  • Fork overhaul procedure - Regular user, link -Technical user, link
  • FZ6/8/1, FZS(6/1) - Blue Spot caliper service - link
  • LED bulbs for the headlight - link
  • Power/Voltage drop tweak/fix for headlight - link
  • Exup Valve - link - depending on per-year mileage, this should be done every 3 months or twice a year.
  • Wheel Bearing & Seals - link
[size=1.35em]Gen2[/size]
  • Mirror mod, FZS mirrors on FZ1 - link
  • Spongy brakes on ABS gen2 - link
  • Replacing ignition keys - link
  • Changing the handlebars - link
  • Engine warning light on & fault code 34 - link
  • Generator rotor rebuild - link - but its safer to just replace the rotor - link
  • Generator rotor bearing/s replacement - link
[size=1.35em]Misc[/size]
  • TFT Dash project - link
GEN1 - deffinately need EXUP service as common maintenance, maybe link to Pats guide - http://www.cartestsoftware.com/fz1/exupmaintenance.html
Thanks Pie, added.
None of the links in the OP work since the site change. Can the links be updated?
FZS 1000 Gen1 (2003)
Tiger 900 GT Pro (2020)
