Brake pad retaining pins
hi all.
Quick question.
Should I coat new brake pad retaining pins with a thin film of worth’s brake paste or just the ends that are in the Caliper.
The only grease I use is a little red rubber grease when cleaning/replacing brake pistons/seals. No need for any grease or lubricants anywhere else.
FZS 1000 Gen1 (2003)
Tiger 900 GT Pro (2020)
Everyone to his own I've always put a bit on the pins just because the pads move along them,it might not do anything but I've done it for years now,it's probably a habit. Wink
same here, a thin film of copper grease on the pins.
Yep, me too. Use the same high melting point copper grease that I use on the exup valve. Some on the back of the pads as well.
I used to do the same but stopped using copper grease 2-3 years ago and it is so much easier to keep the callipers and pads clean and working well. I found that copper grease just attracts all sorts of grit and crap turning into grinding paste and for no real benefit. From what I remember, there is nothing in the service manual about using grease anywhere on the pads or pins.
A rub with copper grease stops them corroding and makes them much easier to remove next time.
I’ve got titanium pins in the front and OEM pins in the rear. No rust or corrosion on either. Regular cleaning and maintenance is the key.
Thanks for the replies.
Blue spot calipers are great calipers and I have only ever had one seize up on me despite my lack of brake maintenance and riding all year round.
I recently saw a delboy video where he shows caliper maintenance so I thought before this winter really sets in with the gritters out and about I would treat said calipers to new pad pins all round and a good wash.
Feeling guilty about my Caliper abuse.
Delboy’s videos are good for entertainment value, but that’s about all....
Where did you get the titanium pins from please?
(21-11-20, 09:28 PM)teecee90 link Wrote: Delboy’s videos are good for entertainment value, but that’s about all....
+that one  :lol
(26-11-20, 05:57 AM)kralik link Wrote: Where did you get the titanium pins from please?
https://www.racefasteners.co.uk/product-...pins-98-06
(29-11-20, 11:47 PM)teecee90 link Wrote: [quote author=kralik link=topic=26619.msg321667#msg321667 date=1606366648]
Many thanks?
