I put a see through type fuel filter on my fazer, I can see the petrol squirting in but it's only half filled the filter, should it be full up
or is it a lazy fuel pump ??
		just a little air locked nothing to worry about as long as everything is running fine
any fuel leaving will be getting replaced by the pumps negative pressure
some jiggery pokery with the hoses can get the air back up the line and back into the tank but it can be a ball ache
		Thanks for the quick response guys, phew!!  :lol
		Mine is never full. As long as the carbs are getting enough, its good enough.
