08-04-20, 10:21 AM
Hi all,
Just wanted to know the best way of removing the chain case cover to get to the front sprocket?
Chain Case Cover
08-04-20, 10:21 AM
Hi all,
08-04-20, 10:48 AM
You'll have to remove the gearchange linkage first, then the sprocket cover. One end of the linkage is left hand thread. Make a note of how much thread is used as you dismantle, so that the gear lever can be returned to its current position.
08-04-20, 10:58 AM
(08-04-20, 10:48 AM)robbo link Wrote: You'll have to remove the gearchange linkage first, then the sprocket cover. One end of the linkage is left hand thread. Make a note of how much thread is used as you dismantle, so that the gear lever can be returned to its current position.This is the bit i wasn't sure about removing, which end is the left had thread? and what will be the best way of removing gearchange linkage?
08-04-20, 11:02 AM
hi wayne...remove the foot rest and linkage in one piece,disconect the linkage from the gearbox end...three hex bolts hold the footrest to the frame...
08-04-20, 11:19 AM
« Next Oldest | Next Newest »
