03-02-20, 10:33 PM
I've just fitted some renthal 785's and was wondering what drill and tap I will need t be able to fit original bar ends?
Renthal drilling and tapping
03-02-20, 10:33 PM
Yep, M16 at 16 tpi(threads per inch).
04-02-20, 05:54 AM
when i took it to a engineer he told he it was a M16 x 1.5 taper tap and a 14.5 mm drill bit?
If you have access to an engineering workshop, I believe the proper way is to predrill the bars before tapping them. My pal on the otherhand just wound the tap into the bar and it worked out fine. I paid for the workshop process to the tune of £35 :eek . My pals bars cost him a pint in the pub. :lol Pretty sure the 1.5 x the tap size is the same as 16tpi, but stand to be corrected
04-02-20, 03:22 PM
(04-02-20, 09:38 AM)robbo link Wrote: If you have access to an engineering workshop, I believe the proper way is to predrill the bars before tapping them. My pal on the otherhand just wound the tap into the bar and it worked out fine. I paid for the workshop process to the tune of £35 :eek . My pals bars cost him a pint in the pub. :lol Pretty sure the 1.5 x the tap size is the same as 16tpi, but stand to be correctedso he just tapped them without drilling them first?, has anyone else done it this way?
04-02-20, 04:06 PM
04-02-20, 06:52 PM
Well and truly rinsed for £35...even the receptionist could do that in 5 mins with all the right tackle
04-02-20, 08:03 PM
yeah watched a video on doing it and it only took 2 mins to do one side
04-02-20, 08:07 PM
(04-02-20, 06:52 PM)74eldiablo link Wrote: Well and truly rinsed for £35...even the receptionist could do that in 5 mins with all the right tackleI nearly walked out and left him with the bars. Apparently workshop time is £70 an hour, minimum charge half an hour. Should have asked first I suppose, but thought it was a 5 minute job and would be priced accordingly. Lesson learnt, for sure. :'(
05-02-20, 05:17 PM
Well, Tap came today so had a go at tapping them, and everything went real smoooth, and bar ends fit perfectly :thumbup
« Next Oldest | Next Newest »
