4mm connector for headlight mod.
Hi lads. I’m going to do the twin headlights mod on my bike. Rather than chop the green wire and bypass the block, I want to add a extra wire from the female side of the connector block to make it look OEM. I’m struggling to find the 4mm female spade connector with locking tab that I need though. Has anyone got any ideas? I’ve been looking online for hours with no joy.
I think I got terminals that fitted the connector block from these guys when I did the mod
https://www.vehiclewiringproducts.co.uk/
Double check it's a 4 mm connector you require & not a 2.8 mm.  [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img]
Thanks for your replies lads. It is definitely a 4mm terminal I need. I’ve just had a look on that site, couldn’t see one but I found a site earlier called Autosparks that do sell them. I just need to ring them when they re open and check that the terminal has the lock tab on.
I’ll keep you posted. ?
As they sell a cover for the terminal then it will have the lock tab.
Good point!! Thanks for that mate ?
Remember when you do this mod you need to adjust the reflector, or you will blind on coming traffic.  The right hand lamp reflector is high beam only doing this mod is a trade off as you will lose high beam performance to stop blinding on coming traffic.
You're better off fitting some like Philips X-tremeUltinon LED bulbs not cheap but they work a treat, or you can try the cheaper GT Ultra I've not tried these myself.  [color=rgb(51, 51, 51)]
    [/color]
Later
