07-07-19, 05:09 PM
okay just changed me front wheel and it feels a little tight... if you give it a spin rotates about two turns and stops is that okay or do you think it needs to spin more??
Front Tyre free spin
07-07-19, 05:09 PM
07-07-19, 05:24 PM
(07-07-19, 05:09 PM)psyfi_1 link Wrote: okay just changed me front wheel and it feels a little tight... if you give it a spin rotates about two turns and stops is that okay or do you think it needs to spin more??Sounds ok to me, infact if it did not stop quickly I would think there was something wrong. The pads still slightly touch although released which stop the wheel from fully freely spinning
07-07-19, 05:58 PM
okay mate cheers just satisfying my paranoia lol
07-07-19, 06:29 PM
with or without the calipers in position?
10-07-19, 01:35 PM
If the calipers are working properly then the wheel should spin freely regardless.
But when you remove the wheel you upset the position of the caliper ever so slightly, so it will take a very short time for the pads to bed in again in a different position than they were before. It’s only minimal but can cause a little friction, similar to when you put new pads on, or if you’ve put the pads back on different sides when refitting them.
« Next Oldest | Next Newest »
