braided brake lines
ok just been having a search around for some new brake lines (its about time i replaced them on the old girl)
and came across wezmoto , they seem ok and read a lot of reviews all over the place as when it comes to brakes i read everything i can on even the smaller companys (in case they aint had the good chances against HEL and GOODRIDGE)
they seem to do two kits for the fzs600 a OEM standard and a full length race kit (cheaper ?)
the only difference i can see is that OEM=4lines, RACE=3lines
i can only assume this is a duel banjo on the master cylinder and a line to each caliper for the race kit (positives and negatives on this)
i have contacted them to confirm if this is the case and dont mind if it is with my future plans but if you guys know anything please share your knowledge
i told them i am on here and doing install videos etc to let everyone know the difference so hopefully they should get back to me with everything we all need to know.
This brings back nightmares for me.  :'(
I got new Venhill lines over 5 years ago and they've been absolutely fine.
http://foc-u.co.uk/index.php/topic,4547....#msg220983
+1 for venhill
[color=rgb(51, 51, 51)]Racers use 2 lines as the ACU Governing Body banned cross over lines as tyre or mudguard failure could and has severed the cross over line causing crashes.[/color]
(31-01-18, 01:43 AM)Disorderlypunk link Wrote: ok just been having a search around for some new brake lines (its about time i replaced them on the old girl)
You are correct the race kit comes with two front lines direct from master cylinder to each brake caliper & not three as standard setup.
There is a discount code if you chose Hel which covers their entire range including fluid. The 2 or 3 lines is a personal choice. I kept the splitter and went for 3 lines as you know already how neat it is going to look. Two lines would obviously be cheaper.
(31-01-18, 11:37 AM)robbo link Wrote: There is a discount code if you chose Hel which covers their entire range including fluid. The 2 or 3 lines is a personal choice. I kept the splitter and went for 3 lines as you know already how neat it is going to look. Two lines would obviously be cheaper.
Never gets old  :lol
.jpg   Cm9Xd_LWAAEcwjG.jpg (Size: 17.76 KB / Downloads: 102)
How much do you hate the Romans. :rollin :rollin :rollin
(31-01-18, 01:43 AM)Disorderlypunk link Wrote: the only difference i can see is that OEM=4lines, RACE=3lines
I thought the OEM brakes were 1 line from the master to a splitter and then one to each caliper = 3 lines.
A race setup would be 2 lines direct from the master to the calipers.
(31-01-18, 05:52 PM)BBROWN1664 link Wrote: [quote author=Disorderlypunk link=topic=23720.msg274825#msg274825 date=1517359414]
full setup so +1 for the rear
Anyone know the code for discount on the hel lines ?
Set Fazer's to stun
(31-01-18, 09:23 PM)matt7chunk link Wrote: Anyone know the code for discount on the hel lines ?
Don't know if this approach still works:
http://foc-u.co.uk/index.php/topic,17552...#msg202525
intresting how i mention wezmoto and everyone jumps to hel
it states in that link posted above that wez pops down and makes them for his ebay shop using there gear
there are not to many wez's in the world so im happy to guess its the same guy
unfortunatly he hasnt emailed me back yet so i have got more info on here by dinnertime than i did all day from wez lol
(31-01-18, 09:58 PM)stet link Wrote: [quote author=matt7chunk link=topic=23720.msg274869#msg274869 date=1517430181]
Lovely thank you , after reading that about wez I just ordered these in red https://rover.ebay.com/rover/0/0/0?mpre=...0993204427
Set Fazer's to stun
yep there the ones i was looking at lol
and ordered them aswell now - same price on there website
- when your arrive could you measure the lengths for the front as i asked him to add an inch on mine for my renthals and future MC replacment
No problem , I have renthals 758 ultra lows so I figured the standard lengths should be fine for me
Set Fazer's to stun
(31-01-18, 08:55 AM)celticdog link Wrote: [size=1em]+1 for venhill
[color=rgb(51, 51, 51)]Racers use 2 lines as the ACU Governing Body banned cross over lines as tyre or mudguard failure could and has severed the cross over line causing crashes.[/color][/size]
Sorry to be a nerd. You can use a splitter on a race bike under ACU regs, as long as the splitter is not lower than the bottom yoke.
Feel the Fear and do it anyway!
Read about my Project Ruby Racer - FZS 600 Custom build Click this link > > > http://foc-u.co.uk/index.php/topic,10613.0.html
im running 789's and they are a bit tight with the oem lines (thank god for the splitter in this case)
the 789 streetfighters are a little bit higher and longer looking at the comparison tables so you should be fine with 758's
im sure the first renthals i bought for this bike were 758 but they were twisted to buggery - nice angle for them though
(01-02-18, 12:43 AM)Ruby Racing link Wrote: [quote author=celticdog link=topic=23720.msg274831#msg274831 date=1517385327]+1 for venhill
Sorry to be a nerd. You can use a splitter on a race bike under ACU regs, as long as the splitter is not lower than the bottom yoke.[/quote]Ruby Racing we are nerds together
14.22 BRAKES For machines fitted with two front disc brakes, a split of the front brake lines for both front brake calipers must be made at or above the lower fork yoke
there are some bikes with the splitter underneath the lower yoke so its prob just a 'do em all' solution
(01-02-18, 12:52 AM)Disorderlypunk link Wrote: [quote author=Ruby Racing link=topic=23720.msg274893#msg274893 date=1517442198][quote author=celticdog link=topic=23720.msg274831#msg274831 date=1517385327]+1 for venhill
LOL. We certainly are. However you have the edge. I nearly searched for the relevant clause in the ACU handbook, but didn't. You however........................ :lol :lol :lol :lol
