tool for fork rebuild
Unfortunately I've got a leaking seal so it's time to do some maintenance the bank holiday weekend. To loosen the bottom bolt (M8)on the bottom of fork leg, requires holding the inside damper rod- the usual method is to use a broom handle.
Manual refers to Yam tools (90890) but no idea of what it looks like. From memory I think it's a hex. If I knew the size and shape I could weld something onto a long rod and reach down there.
Has anyone made similar or have any ideas with size and shape help?
I used a broom handle.
^^that's what I did. I had a 1m length of wood  about 30mmx20mm. I whittled the last 4inches into a tapered point. Just give it a whack and it wedged in and I could prevent it from turning whiled I shocked the bolt out.
I made a seal seating tool using one bit of split plastic tube inside another with a jubilee clip on the outside
-suck-squeeze-bang-blow-
I think I might have some lying around that I made for the tdm, might be the right size.
Can post one or if you want to try it.
(\__/) This is bunny. Copy and paste
(x'.'x) bunny onto your page to help
(")-(") him gain world domination!
(23-08-17, 02:27 PM)celticbiker link Wrote: I think I might have some lying around that I made for the tdm, might be the right size.
Nice one can you stick up a pic fella, then I can see what it looks like.
http://www.ebay.co.uk/itm/Wooden-Broom-H...0338.m3726
celticdog,this may help ya.[img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img]
https://www.youtube.com/watch?v=vrmYJgcGX30
(23-08-17, 03:46 PM)BBROWN1664 link Wrote: http://www.ebay.co.uk/itm/Wooden-Broom-H...0338.m3726
:rollin :rollin :rollin
:lol that's the 15/16 " broom I thought you needed to use the 24mm version.
There's a photo of a fella holding said tool on this, as well as it being good clear instructions for the job:
http://fazerowners.yuku.com/topic/23188/...es-and-Oil
I’ve found some dimensions online! It’s basically a square taper shape. I’ll get me pen knife out.
.png   tool.png (Size: 31.43 KB / Downloads: 49)
.jpg   toool.jpg (Size: 11.02 KB / Downloads: 49)
this is what i made . bit of softwood whittled down . as your drawing 20ish mm...
.jpg   20170824_110156.jpg (Size: 121.34 KB / Downloads: 45)
.jpg   20170824_110116.jpg (Size: 41.42 KB / Downloads: 45)
old 1/2 inch extension ans grind it to the shape
