14-07-17, 05:28 PM
are renthal 758s ok to use on the 600, I have a spare set well, going spare really.
Renthal 758
14-07-17, 05:28 PM
Yeah, work fine. Bit wider, and you'll need different bar ends. Got pair on mine at mo, you need to get them at right angle so they don't clash with fairing/mirrors or tank, but no big deal. The width took a bit to get used to and can be a bit of stretch for full lock.
Some pics on my blog here: http://www.beginnerbiker.com/2015/06/ren...rs-review/
15-07-17, 08:48 AM
Cheers, will get hem swapped over.
15-07-17, 12:48 PM
And you'll either need to drill location holes for the tabs on the switch gear, or tape up the area to stop them rotating. Apparently Renthal advise against drilling, but I did.
15-07-17, 07:06 PM
More than ok, I put a set on my Fazer 600 and haven't regretted it since, feels so much more comfortable now
17-07-17, 03:33 PM
(15-07-17, 12:48 PM)mtread link Wrote: And you'll either need to drill location holes for the tabs on the switch gear, or tape up the area to stop them rotating. Apparently Renthal advise against drilling, but I did. Yeah, I filed off the location tabs then used 3 or 4 layers of silver foil between the switch gear and the bars, nothing's moved in 4 years. I didn't fancy drilling holes in mine.
Eagles may soar, but weasels don't get sucked into jet engines...
17-07-17, 07:42 PM
I don't know where all this talk of holes is coming from? :rollin I didn't have to drill a single hole in mine when I put them on
19-07-17, 06:38 PM
So much better than the standard bars. I filed down the tabs a bit and they've been fine =)
Chris |
« Next Oldest | Next Newest »
