Running like a dog
after messing with fuel tank sender issues. Bike is now running on three cylinders.
Changed the plugs as you do.
No better. Looks like a disturbance somewhere. Or the carb rebuild wasn't as good as suggested.  :eek
did you do both at the same time carb clean and sender ? are you getting a spark on that cylinder ?
Check you haven't kinked the breather tubes.
Firing on three - determine which cylinder has the issue by the temperature of the down pipes (put some spit on it).
switch the spark plug caps over swap 1 with 4 and 2 with 3. See if the problem moves. If it moves it's an electrical fault if it doesn't it's a carb/fuel fault.
-suck-squeeze-bang-blow-
Or a spark plug fault.  If fault stays in same place after swapping leads over try swapping spark plug with the one next to it and see if fault moves with the plug
Start where you last disturbed thing - playing with the tank sender unit shouldn't affect plugs etc. Check the easy of obvious first. Then move on.
Moving the tank could also disturb water and crud from the bottom. The fule filter should take care of most of th crud. Ethanol (meths) will absorb water if added to the fuel.
(17-04-17, 10:30 PM)Jules-C link Wrote: Or a spark plug fault.  If fault stays in same place after swapping leads over try swapping spark plug with the one next to it and see if fault moves with the plug
Although the OP did say they had changed the spark plugs.
Spark plugs were changed first.
Removed tank, no obvious issues.
Removed carbs to see what has been done. Someone has been inside as there are scratch marks in the bowls.
Rubbers to the manifold, have a few cracks. But nothing seems to be right through. Like was suggested they would be ok on here
Carbs 4 and 3 seperated, just awaiting ultrasonic cleaning fluid. Then I shall do each carb one at a time.
I think, but I need to confirm, that three of the four pilot jets are blocked.
No carburettor expert here. But I'm lead to believe they are the issue for idling.
A bit more cleaning today as I'm on-call.
Removed fuel tap. It was full of shit.
Emptied all the fuel out and that was also full of rust from the fuel tank.
Washed the tank out. Now filled with vinegar for a few days whilst the cleaning fluid rocks up.
(24-04-17, 04:01 PM)Koreanbaz link Wrote: Now filled with vinegar for a few days whilst the cleaning fluid rocks up.
Why?
Malc
Old enough to know better.
(16-04-17, 06:31 PM)Koreanbaz link Wrote: Running like a dog
Is it only me that sees the funny side of this post from a poster by the name of  Koreanbaz?
(25-04-17, 04:21 PM)BBROWN1664 link Wrote: [quote author=Koreanbaz link=topic=22386.msg258523#msg258523 date=1492363896]
Running like a dog
the place where dogs run the fastest lol
Nothing wrong with Korea. Especially the food!
I hear their meatballs are the dogs bollocks!
Running like a dog
Maybe it should have been "running like my dinner!"
