25-06-16, 03:07 PM
Decided not to take the bike off the road for a week + so sprayed them with Simoniz black enamel engine paint.
Will powder coat in winter when off the road.
Used the card trick for the tyres
Remove sprocket
Remove discs
Degrease wheels
Mask off bearings
Sand down with wet "n" dry
Degrease again
Mask areas not to be painted
Several coats of Simoniz
If you bend the cards down you can flip the wheel over without damaging fresh paint, the tyre will keep the rim off the ground.
This way you can spray both sides without a dry line.
Spray the wheel and remove the cards before paint dry's or the cards may stick and tear.
Have to say the simoniz gave a powder coat finish and was much better than expected.
Very impressed but will not last like powder coat or be as durable, but for a nice summer look without the loss of use it was worth less than £20
Paint £7 Amason
Wet n Dry £2 pound shop
Thinners £5 motorist centre
Masking tape £1 pound shop
4 packs cards £2 pound shop
The cleaning and prep always takes longer than the spraying
Remove sprocket
Remove discs
Degrease wheels
Mask off bearings
Degrease again
Paint £7 Amason
