Anybody fitted SRAD forks to a 600 Fazer?
Or more to the point can the stem's be swapped?
I know every man and his dog uses R1 forks but got these cheap
Answers on a postcard please Big Grin
The stems will need to be swapped... Local engineer job. I doubt the average person will be able to do it. You may need spacers as well. I only used an R1 on my FZS because as you said I got them cheap but even they are not a straight swap and require the stems swapping and a spacer under the top yoke.
If you go through with it make sure you fit the srad600's 4 pot calipers not the 750's 6 pots as they are shocking!
Some say...
(10-12-15, 11:39 PM)Punkstig link Wrote: If you go through with it make sure you fit the srad600's 4 pot calipers not the 750's 6 pots as they are shocking!
Found a set of four pots and a pair of Ferodo disc's for just over £90. Need to find someone to press out/in the steering stems now
After a SRAD USD lower yoke if anyone has one kicking around
