25-11-15, 10:19 PM
Hi.......just picking fzs1000 riders brains...i need to get new rear wheel bearings.....where is the best place to get them from...i have no problems fitting them,
ta
ta
25-11-15, 10:19 PM
ta
25-11-15, 10:50 PM
I got mine from Wemoto .
25-11-15, 10:55 PM
I got a set from Markman Industrial. Or was it All Balls Racing. If forget.
If a bearing has failed, the roller caged one is a bastard to remove. It kind of welds itself into the aluminium of the wheel. Good luck!
The needle roller one does not normally give trouble unless the right side one is totally focced.
Replace the external right seal when replacing that bearing Marksmans or WeMoto is where I usually get mine if I cannot get them in the local bearing shops
26-11-15, 11:33 AM
Marksman does the kit with everything you need. They have changed their website so it is much harder to find, but the kits you want have the codes 'YA001' for the rear wheel bearings and seals and 'YA002' for the sprocket carrier.
http://shop.marksman-ind.com/ya001-rear-...2-20-p.asp http://shop.marksman-ind.com/ya002-fazer...t-22-p.asp
26-11-15, 12:40 PM
i bought the kit from marksman also. good prices way cheaper than yamaha
from the minute your born you are dying, so make the most of it and live life to the max
26-11-15, 05:16 PM
26-11-15, 05:18 PM
thanks for all your assistance....very helpful....
« Next Oldest | Next Newest »
