Who rebuilt my rear brake, focin lazy previous owner
Had split the rear caliper prior to painting as suggested by someone on here, after looking at the pistons I noticed one was further out than the other, and after trying to move it I understood why, seized rear caliper syndrome. On the bench, gently rotating said piston reviled only one seal each side, someone obviously didn't think two seals were required  :wall
Tbh the pistons look fine and hopefully the remaining seal will be OK to reuse, just hope I can source some outer seals (dust?)
It's amazing what some people do just to save a few pence. Lucky you found it and nothing serious happened.
Malc
Old enough to know better.
Found a set for £3.00 for both dust and piston seals, so £6.00 plus postage wont break the bank
Id go through the whole bike just in case they f
(12-11-15, 05:15 PM)bootz76 link Wrote: Id go through the whole bike just in case they f
Found two dust seals missing from the rising rate link and one spacer/washer from the swingarm pivot.
Hope they've not been inside the engine, be lucky to find any piston rings
(12-11-15, 09:13 PM)joebloggs link Wrote: [quote author=bootz76 link=topic=18713.msg215855#msg215855 date=1447344945]
And all this coz someone showed you that the rear caliper split?  :rollin
You best make sure the missing seals aren't on the pistons :eek
Colin
(12-11-15, 10:47 PM)sinto link Wrote: [quote author=joebloggs link=topic=18713.msg215883#msg215883 date=1447359219]
I didn't know there was an issue with the brake, I've not ridden the thing yet, only pulled it apart to paint it (think it was yourself that suggested parting it) The outer seals (dust) are missing, piston cleaned up OK and the set ordered come with new piston and dust so be stoopid not to use them both.
(12-11-15, 11:09 PM)joebloggs link Wrote: (think it was yourself that suggested parting it)
Yes, it was me Smile
You should use the complete new set for all they cost.
Colin
(12-11-15, 11:20 PM)sinto link Wrote: [quote author=joebloggs link=topic=18713.msg215895#msg215895 date=1447366191]
Yeah and going to pull the fronts apart now, was just going to clean and copperslip them but after finding the previous owners handy work I have no choice
(12-11-15, 11:24 PM)joebloggs link Wrote: [quote author=sinto link=topic=18713.msg215896#msg215896 date=1447366830]
Oh I see another anutz rebuild coming :lol
Colin
(12-11-15, 11:27 PM)sinto link Wrote: [quote author=joebloggs link=topic=18713.msg215897#msg215897 date=1447367094]
If a jobs worth doing!!!  :b ......at least its being done in winter as opposed to my summer fun
