exup valve wanted
hi has any one got exup valve to fit my gen 1 fazer 1000 cheers
What's wrong with the existing one? if its bent but not too bent it can be bent back - just use the soft mallet and a veriable speed drill technique.
worn down one end and rattling tits of so still looking for one
RMT1983 has one
(24-10-15, 11:36 AM)donkey link Wrote: worn down one end and rattling tits of so still looking for one
Take it to a machine shop, have it built up or a bush made up to suit the wear
(24-10-15, 01:31 PM)unfazed link Wrote: Take it to a machine shop, have it built up or a bush made up to suit the wear
IMHO, getting a phosphor-bronze bush made up would only work if the wear on the shaft of the valve is even.
Machine shop could regrind the end to make it round if necessary
(25-10-15, 07:58 PM)unfazed link Wrote: Machine shop could regrind the end to make it round if necessary
Ah yes, forgot about that. The only issue there is would they be able to re-harden the surface afterwards..? (assuming the ends aren't hardened all the way through)
Heat it well and let it cool in soot will harden it  Smile
