For Sale - 2003 FZS1000 - £1650 ono
I bought this last year as a Cat "C" damaged bike project to fix up and get back on the road. I've just bought a new bike which cost me a few quid more than I was planning, so this one has to go. It had taken a whack to the front end so forks were mullered, front wheel had a big ding in it, fairing was badly damaged, bars bent and levers snapped.
It's now fixed and ready to ride with a new years MOT. Currently on SORN. I read that it can be sometime tricky to insure Cat "C" bikes, but I had to insure this in order to ride it for it's MOT check & had no problems at all.
Bike has 52k miles on the clock.
The work done, any parts replaced were either new or used from a low mileage bike:
Used forks fitted
Wilbers rear shock fitted (approx 12k miles on it)
Carbs cleaned out as they had old fuel in them
Fairing replaced & given a respray
New EBC brakepads fitted front & rear.
Replaced all disc bolts
Low mileage downpipes fitted, new exhaust studs & nuts
Standard exhaust can fitted
New Renthal low bars with R&G bar ends
New aftermarket brake & clutch levers
Replaced radiatior, this has been checked & leak free
Complete wiring loom replaced as the bike was originally fitted with a very complicated alarm which I wanted to ditch.
New battery
Any nasty anodized bolts replaced with stainless/originals
Low mileage seat
Suspension linkage replaced & regreased.
New sealed steering head bearings
Wheels checked & adjusted for allignment.
Dent in front wheel repaired
All the work on the front end (head bearings etc) was checked by my local bike engineer & got the thumbs up.
Still to do:
Probably could do with a service, oil change, plugs etc. The bike has no service history so I can't be sure as to the last time that was done. EXUP cable may need adjusting. The valve works fine, but the cable has an adjuster, so I don't know if that is at the correct setting, this should be looked at as part of the service.
There is a faint rattle at the header pipes, not quite sure what causing it, it's not awful, sounds a little
like a cam chain rattle.
I think thats about it, I've tried to be as upfront as I can so there should be no surprises.
As the bike is on SORN I can't offer any test rides I'm afraid.
Drop me a PM if interested. Based in Leighton Buzzard, Bedfordshire.
![[Image: DSCF0014_zps39bennnq.jpg]](http://i115.photobucket.com/albums/n288/chrisrumble1969/DSCF0014_zps39bennnq.jpg)
![[Image: DSCF0016_zpsgwsfj9xk.jpg]](http://i115.photobucket.com/albums/n288/chrisrumble1969/DSCF0016_zpsgwsfj9xk.jpg)
![[Image: DSCF0015_zpsjsxnpnsv.jpg]](http://i115.photobucket.com/albums/n288/chrisrumble1969/DSCF0015_zpsjsxnpnsv.jpg)
![[Image: DSCF0013_zpsjvvz5skw.jpg]](http://i115.photobucket.com/albums/n288/chrisrumble1969/DSCF0013_zpsjvvz5skw.jpg)
![[Image: DSCF0017_zpsk89hdwdr.jpg]](http://i115.photobucket.com/albums/n288/chrisrumble1969/DSCF0017_zpsk89hdwdr.jpg)
![[Image: DSCF0018_zpskswx5wf2.jpg]](http://i115.photobucket.com/albums/n288/chrisrumble1969/DSCF0018_zpskswx5wf2.jpg)
![[Image: 125377.png]](http://mefi.us/images/fuelly/smallsig-uk/125377.png)
