15-09-15, 02:28 PM
Well sort of
The previous owner has done some sort of mod, doesn't appear to be the same as the one on here and I want to remove some of the wiring as I'm having single headlight only.
present wiring
Black/blue and black. to one light connector
black/white, black and green to second connector (this maybe a pre wired aftermarket connector)
The top pin of the three is connected to the green wire coming from the left side handlebar switch block.
Is this correct and if so is this the connector that will give me low and high beam on a single headlight
present wiring
