Nightmare. The same thing happened to mine over the winter. The rear indicator went through the undertray too so I've had to replace the undertray.
Fairings new are around £180, mine has been repaired by a friend who's a paint sprayer.
I'm a plastic welder and can repair those cracks but you'll have to find a sprayer to repaint it as I no longer have access to a booth
Deefeer666 where do you live roughly I would be very interested in repair, I could find a painter easy enough I rekon.
My workshop is between Huntingdon (cambs) and Thrapston (northants)
(14-06-15, 02:38 PM)humphreys38 link Wrote: So my lovely fzs600 boxeye 97 blew of its centre stand in the wind... I parked on a slight gradient to its left side I no idiot... School boy error...
Tom Sorry to hear about the damage, schoolboy error or not, you'll learn, hopefully :rolleyes
You seem to be getting the help you needed, the only thing I would say is that you said your hand bar was scuffed?
I'd seriously think it's been bent and would really need checked, if it dented your tank as in the pics, I don't think it would 'spring' back into shape.
Only other thing I would say is that I park on inclines with sidestand and bike in gear, mind you, I always park with my bike in gear, as I do with my car
Colin
14-06-15, 07:19 PM
(This post was last modified: 14-06-15, 07:22 PM by anutz.)
shame about the drop, but at least yours just fell on its side, mine slid a few meters the opposite direction to me, after it spat me off, anyway one thing i did after that was put some crash bobbins on - i then laid it on its side in the garage i.e. dropped it :lol and the only thing that touched
was the bobbin and maybe the clutch lever but it was only a scratch and i think it if there was no boxes in the way it would not have touched anything... so the indicators, crank case etc, not further damaged
agree with Sinto on checking the bars, but the dent is identical to the one mine has when i got it so i now know the last owner dropped it, not
bothered bit its nice to know!
going to check my bars now actually now i thing about Sinto's point :'(
Deffer666 dammit, thanks for The info but I live in bodmin Cornwall, bit to far unfortunately, I going to get me a soldering iron and some plastic and try to patch up the fairing for now, the bars look straight but I wouldnt be surprised if they had a slight bend in them, I should prob get them checked at the same time as getting the tank fixed, I was thinking of going to a tail tidy so I suppose I could just take the underside of the back altogether anyway?
Unfortunately I actually bought the bike and had the crash bobbins put on it but because of the centre stand putting it on high and I left the side stand out it managed to jump over the bobbins!! It my first big bike so I suppose a fall was due ...
Thanks for the advice
Tom,
Should be fairly easy to check your bars, turn them both ways and see if the gap between the bars and tank is the same both sides, admitted you have a bash on the tank, but you can use the front fairing too.
I've actually got some plastic on ebay
URL: http://pages.ebay.com/link/?nav=item.vie...12&alt=web
Just wanting rid of it, if you want it give me a shout and pay the postage, you can have it and I'll pull the auction for you, or if you want to bid on it and win it, I'll reduce the Postage to compensate for it, whatever way, i just want rid of it and if it helps a fellow foccer that's a good thing in my book.
Colin
Ah now I have never done a plastic weld job before can I just melt that plastic down to use in the restructuring and welding of the cracks with a soldering iron?
(14-06-15, 09:51 PM)humphreys38 link Wrote: Ah now I have never done a plastic weld job before can I just melt that plastic down to use in the restructuring and welding of the cracks with a soldering iron? Nor have I as a pro, but I bodged a job years ago using a heat gun, done the job I wanted and was covered with panels etc, so it never bothered me, best asking deefer for some hints I'm guessing ;-)
Colin
What sort of plastic is the fairing? I'm thinking of repairing the cracks in my fairing sometime and some matching filler plastic would be nice!
Does any one no if later larger fuel tanks would fit the old 98 fzs600 ?
(20-06-15, 05:10 PM)humphreys38 link Wrote: Does any one no if later larger fuel tanks would fit the old 98 fzs600 ? Yes, no bother.
(20-06-15, 05:10 PM)humphreys38 link Wrote: Does any one no if later larger fuel tanks would fit the old 98 fzs600 ? Yes, but why bother when you can open the hole up a wee bit in the filler neck and get the same result, albeit after you fill, you have to keep it upright till you've used a bit of fuel up so it doesn't just go down the overfill tube and run out the bottom of the bike. :rolleyes
Colin
