Paddock Stands...
Just a bit of info, I ordered one of these as they look good....
http://www.ebay.co.uk/itm/400908897249
I shall let people know if it works ok - I tried to do some work with the bike jacked up and putting the wheel back in on my own with no paddock stand was almost impossible
I like this one as it seems it will not get in the way of any removal of the axel or sensors etc..
Never had a problem with doing that work on the centre stand!
Some say...
How do you get the front wheel clearance off the ground - I don't want to be wedging crap under the exhaust as I have had problems when I snapped an engine stud and don't want to put load where it should not be....?
I have a box full of lead (180lb) which I put on the ground and attach to the passenger handles with ratchet straps.
Malc
Old enough to know better.
Did you check the width before placing the order? it doesn't look adjustable
no  Smile
But it does list the FZS 600 as a compatible bike....
I put my toolbox on bike rack when taking front wheel off and insurance policy of a jack under exhaust but it's not really taking any weight
I am scared to do anything that touches or puts pressure on the exhaust after the trauma I just went through Smile
So the stand for 40£ is hopefully spot on
Handy hint for getting a bike on a rear paddock stand that only has a side stand - put the side stand on a bit of wood to raise the bike up more to the vertical 8)
(29-04-15, 01:26 PM)noggythenog link Wrote: Handy hint for getting a bike on a rear paddock stand that only has a side stand - put the side stand on a bit of wood to raise the bike up more to the vertical 8)
But don`t let it fall on you! :\
Sorry Noggy, couldn`t resist Big Grin
Do many people remove their centre stand on Fazers, I wandered the other day....?
Forget paddock stands, get one of these bad boys, mines is origanal green though so doesn't match my fast red fzs600
.jpg   r6-on-red-lift.jpg (Size: 25.86 KB / Downloads: 63)
Colin
(29-04-15, 08:23 PM)anutz link Wrote: Do many people remove their centre stand on Fazers, I wandered the other day....?
Rarely, it's normally only removed if the bikes lowered!
Some say...
(29-04-15, 05:17 PM)slappy link Wrote: [quote author=noggythenog link=topic=16785.msg193286#msg193286 date=1430310368]
tbf it was quite easy to work on then on its side :lol
yeh sorry guys...confusing matters there maybe as I got a gen 2 which happens to have had the centre stand removed but that isn't common.......it just made life easier when I heard about it.
Arrived and it does what I want  :b
[Image: FrontStand_zpsrr9k68fe.jpg]
(01-05-15, 07:09 PM)anutz link Wrote: Arrived and it does what I want  :b
Looks smart anutz, that'll let you get working on your front end conversion :rollin
Colin
funny you should say that whilst I was there I unplugged the connector to the instrument panel and started investigating  :lol
(01-05-15, 08:23 PM)anutz link Wrote: funny you should say that whilst I was there I unplugged the connector to the instrument panel and started investigating  :lol
Oh you just can't help yourself, bet you've learned a lot since your first post lol
Colin
oh yes, I remember struggling to get the vacuum caps off the carbs to check the sync....and then its kind of gone nutz....
especially with the exhaust stud snap and subsequent bodge/repair and re-assembly...and I have had to strip it down again as the tensioner gasket I neglected to replace ( should have...I knew it! ) leaked...new ones on the way should be here tomorrow...
so thought I would do the brakes...
what could possible go wrong Smile
At least I am looking at something I am better with soon - electrical/electronic
I'm sure your taking it in your stride :-)
I replied to your brake thread btw
Colin
