Gen1 carb balancing
Hi,
How easy is it to balance the carbs?
once you've found the adjuster screws, really easy. :rollin
Where are they then?
(21-04-15, 05:08 PM)sadlonelygit link Wrote: once you've found the adjuster screws, really easy. :rollin
:agree :rollin
You will need a long Philips screwdriver! After you have found all the adjuster screws it is fairly easy. I think there is a how to guide on Pats motorcycle page.http://www.cartestsoftware.com/fz1/carbu...tion.html.
I used that as a guide the first time I did mine when I had a gen1
[Image: CARBSYNC213.JPG]
except that everything will be covered in crap and wiring loom and possibly the evap system.
a good torch, some tippex and plusgas and the 300mm screwdriver will see it done.
