20-04-15, 06:45 PM
What's best engine oil for gen2? I've had some fully synthetic given castrol power1 racing 10w-40.
Question is will it make the clutch slip?
Dave
Dave
Fz1 which oil semi or fully
20-04-15, 06:45 PM
Question is will it make the clutch slip? Dave
21-04-15, 01:25 PM
I just changed mine from own brand "high mileage" semi-synth to Castrol GTX 10-w40 semi-synth. I think that as long as you avoid anything that mentions fuel economy on the label, you should be fine.
21-04-15, 02:16 PM
Cheers fella, not many get back to you on here?? Reading around its a bit vague on what you can get away with using, sounds like I may be better sticking to semi.
21-04-15, 02:40 PM
Yeah i use Motul Semi Syth. Heard fully may increase slipping.
21-04-15, 04:19 PM
Castrol Power 1 Racing is one of the best oils there is on the market. It was designed for high performance motorcycle engines.
It's in my S1000r & it was used in Mr Brooker's FZ1 for nearly 30k miles until I changed to Halfords fully synthetic.
21-04-15, 05:19 PM
It is odd how many people think fully synth causes clutch slip...
I used castrol power 1 in mine (and all my previous bikes), internals look perfect even after doing high mileage. Currently use Silkolene/fuchs pro 4 fully synth in the gen1, perfect.
Intentionally left blank
27-04-15, 03:23 PM
Well after looking round there seems to be a debate but no one has ever had any slipping
« Next Oldest | Next Newest »
