16-04-15, 09:20 PM
Latest Oxford heated grips £39.99
16-04-15, 11:48 PM
so whats the difference in the 2?
17-04-15, 12:06 AM
Length and thickness of grips. Sports ones are thinner but longer. Controls are just the same though.
https://app.box.com/s/foujlrwwnb5bibsmyt...08311987/1
17-04-15, 06:24 AM
Not available
17-04-15, 11:40 AM
Works fine for me - I'm considering buying a load to stick on eBay!
17-04-15, 02:11 PM
so which ones are going to fit my 02 fazer 1000 best?
The DrBike heated grips use a better controller and only cost £35 -
- http://www.ebay.co.uk/itm/DR-BIKE-HEATED...1e6a1b386e or £25 s/h - - http://www.ebay.co.uk/itm/Dr-Bike-Heated...33a06ffa24
17-04-15, 06:49 PM
(17-04-15, 02:28 PM)b1k3rdude link Wrote: The DrBike heated grips use a better controller and only cost £35 - There £39.99 when I clicked on the link :-( That aside b1k3rdude, you say there better, in what way? I thought the Oxford switch was far better?
Colin
---------------------- Ride fast, ride a red bike :-) (17-04-15, 06:49 PM)sinto607276 link Wrote: That aside b1k3rdude, you say there better, in what way? I thought the Oxford switch was far better?I don't know if its still the case but the previous gen oxford controller used to switch off when the system voltage dropped below a certain amount, and for a lot of people this happened at idle while commuting. The Dr-Bike controller is what Oxford used to use and because its a analogue switch with a potentiometer its 100% reliable. The only prevision is that you wire it into a switched live and not directly to the battery, which you should be doing with any accessories in any event. And in any case the normal retail for the current Oxford grips is £80 which is just plain ridiculous, I bet the BOM is a fraction of the retail.
18-04-15, 06:55 PM
Yes, £80 is a foccin rip off!
But I think the £45 delivered is a fair price if your looking for them. I'd read somewhere about the new switching gear, not being reliable etc, but I think there onto version 6 or something now, it's marked on the controller as v6 it's that in the latest catalogue anyhow. I'd hope by now they'd of sorted out all the issues ;-)
Colin
18-04-15, 08:53 PM
Quote:I don't know if its still the case but the previous gen oxford controller used to switch off when the system voltage dropped below a certain amount, and for a lot of people this happened at idle while commuting.That would suggest their charging system isn't very good .....Current Oxford Hot Grips uses the v8 wired directly to the battery. Been using one on my Speed Triple for the last 2 years without any problems at all. But then I do keep my bikes in good nick These are a steal if you can get them at £39.99 (18-04-15, 08:53 PM)mtread link Wrote: That would suggest their charging system isn't very good ....Correct and on the FZS1000 it isnt, the voltage on a lot of bikes is subpar. Barley managing 12v at idle and only reaching 13-13.5v at very high rpm. Where as my Bandit 1200 gives me 14v at idle. - http://foc-u.co.uk/index.php?topic=15299...#msg173967 The reg/rec and the assoc. wiring on the FZS1000 aren't the best and a permenant fix would be to upgrade to thicker guage wires and a superior MOSFET rec from the R1 or FZS1 (2006-on). - http://foc-u.co.uk/index.php?topic=4820.0 - http://www.triumphrat.net/speed-triple-f...grade.html
19-04-15, 08:19 PM
But the latest Oxford grips only cut out if voltage drops below 11.5v, but which time you've already got trouble.
Anyway, they're fairly easy to switch on again once you're rolling.
03-05-15, 02:54 PM
Free shipping if you get 2 or more as well
06-06-15, 06:17 PM
thank you for the link and code happy days
full licenses don't come in cornflake packets!
06-06-15, 07:40 PM
(03-05-15, 02:54 PM)henrysj link Wrote: Free shipping if you get 2 or more as well You're right fella ![]() Just bought 2 sets....happy days :thumbup
11-06-15, 07:20 PM
cmc motorcycles have them of the shelf for £44..99
« Next Oldest | Next Newest »
