Repainting Garage Door
Bit of a mundane one, but is it ok to use Nitromors on your typical metal, up-and-over garage door? And what's the best way to repaint after? Obviously after cleaning thoroughly it'll need a primer coat before applying paint, but what's the best way - brush ok? I'll source the right outdoor application paint and primer (gloss white finish to replace the ugly old brown colour that comes off with just a wipe with a wet rag now). Don't have any spray guns and don't want to spend that much now, just prepping the house for sale. Cheers Foccers!
I have painted many garage doors Nick.
The best way I have found for finish and speed is to thin down the undercoat and gloss with white spirits and use a roller to apply,  then a large brush immediately after as you are going to get rid of the orange peel effect the gloss roller leaves.
Make sure you use a gloss roller and not an emulsion one and what size you use is up to you but if there ate tricky little panels onit iI would use a 4". If not I'd use a 9" roller and smooth it off with a decent 4" brush.
Failing that, see if Devilsyam can carbon dip it.  Big Grin
Carbon dip  :lol
That would be seriously cool!
Cheers dazza. Is a paint stripper ok on these things? I would guess it's ok, but...
Pics of the strippers please 8)
Nitromoors would be perfect to strip the old paint but glove up and SERIOUSELY watch for splashes. Gentle even brush strokes without flicking the brush. U get that in ur eye you'll fekkin know about it. Goggles preferably. As Dazza said re thinners but I'd recommend a rad roller to apply with brush for the recesses.
(01-02-15, 06:50 PM)noggythenog link Wrote: Pics of the strippers please 8)
http://www.amazon.co.uk/Nitromors-177043...=nitromors
You silly boy  :lol
Yeah I know it's nasty stuff Exup. I won't tell you how I know, but I know... :evil  :lol
Oh dear .....Nick.....you cannot use it as a lube...
(01-02-15, 07:05 PM)Exupnut link Wrote: Oh dear .....Nick.....you cannot use it as a lube...
You don't know what it's like to have haemorrhoids this bad  :eek
(01-02-15, 07:07 PM)nick crisp link Wrote: [quote author=Exupnut link=topic=15867.msg182041#msg182041 date=1422813945]
Just dont use the Flash cleaning wipes instead of the moist tissue wipes by mistake :lol
Why strip it? seems alot of work,,sand it down and a couple of primer coats
(01-02-15, 08:37 PM)slimwilly link Wrote: Why strip it? seems alot of work,,sand it down and a couple of primer coats
Seems to me an application of Nitromors would be easier than sanding. The brown colour comes off at the slightest provocation, but there is a layer of blue underneath too, some of which has also peeled, and then primer. Paint stripper to just take the whole damn lot off.
Save time & money Leave the door up when you have viewings  :thumbup
Don't forget to leave it in the "up" position till its dry to prevent tears
I used to not give a foc, then I discovered Red Bull and now I don't give a flying foc !!!
just a question on this I know Nick mentioned he hasn't got a sprayer but could you buy a cheap garden sprayer and thin the paint down (as mentioned) & use that?
I'm pretty sure the composition of most paintstrippers has changed in the last few years as a result of the dichloromethane ban.Don't know how effective it is compared with the old stuff.
Yes it changed a few years ago and virtually doubled in price for a less effective product!
I used the green can of nitromours recently and it did very little. A heat gun and a scrapper is the way to go if you want to strip it. Heat the paint until it's soft but not burning and it'll come off in big strips. Then a quick sand and clean, followed by undercoat and two top coats and it'll look good and last. A sprayer isn't really going to save you any time because you're only doing a small area and most of the time goes into the prep not the painting.
