Removing heated grips
So i have some replacement handlebars, the mechanical fixings will be ok to remove but the heated grips,,well i guess the are glued on, how do i go about getting them off without fecking them up?
wd40  and something long and flat like metal potato skewer to get between bar and grip and then twist and pull gently Smile
A job for this week nights, i will go careful.ta Neil
Then i got to glue them back on,,what with? any ideas
Try a little contact adhesive.  Or some one posted before about using hairspray.
http://fazerowners.yuku.com/topic/5650/H...5RA78Ysyl0
Use this guide from the old forum, tells you how to get old grips off and what to use to install the new ones, it works as i still have my original grips.
brake cleaner,  Work a screwdriver gently in just a little, then get some brake cleaner with the straw on the nossle and give it a good squirt.  Keep trying to wiggle the grips and more brake cleaner and they will come off unharmed.
Well i got the left hand side off,, its fucked, i thought it was just rubber, so i went prizing the rubber bit from the bars,,only to find it was on a hard plastic sleeve,, i prized that off and they came off,,
They did only work on low heat so were on their way out,,i do have a pair of new ones here to go back on,,from the forum £50 if i remember.
great find skippernick saved me looking - going to wire mine this afternoon possibly
Yup brake cleaner for getting em off, it eats super-glue.
