24-04-14, 08:56 AM
This morning bike wouldnt start no movement with starter motor when i got half way to work touched the switch worked again. when i got to work stopped bike wouldnt work again ? any ideas new motor loose cable ? :'( :'(
Intermittant Starter Motor Problem
24-04-14, 08:56 AM
24-04-14, 09:26 AM
If you download the manual , and have a multi meter it tells you how to check in the electrics section , so at least you can eliminate various things before replacing parts .
24-04-14, 10:39 AM
Side stand switch?
24-04-14, 12:18 PM
ill check these all out tonight under the area of side stand is gunked up to foc. so ill start there.
24-04-14, 12:29 PM
Is it not a bit unhealthy to press the start switch with the engine running?
Quote:Is it not a bit unhealthy to press the start switch with the engine running? pretty sure i was asking for ideas to fix? not what you thought was healthy.
24-04-14, 01:16 PM
Shagged battery? Battery flat so won't work, but pressing it on the go uses power that the alternator is generating?
Not even sure if the system works like, just a wild guess.
24-04-14, 01:20 PM
battery on charge/optimate so not that. thanks tho.
24-04-14, 02:56 PM
As per the manual - Check the main and ignition fuses , check condition of battery , then to check starter motor put a jumper lead from positive battery terminal to starter motor lead 2 ( this check may produce sparks ) does the starter motor turnĀ - if not repair or replace starter motor.
24-04-14, 09:24 PM
(24-04-14, 01:20 PM)brooker81 link Wrote: battery on charge/optimate so not that. thanks tho.I wouldn't take that for granted, I've had a battery show as fine on an Optimate but one cell was dead, the remaining cells gave a good enough reading for the charger to say it was holding 12v but the dead cell meant it didn't have enough juice to turn the starter.
24-04-14, 09:59 PM
As above, just because it's on an optimate, doesn't mean the battery is good...
25-04-14, 09:06 AM
all lights bright on ignition etc i know battery isnt the best tho so may swap that out first.
25-04-14, 09:12 AM
Do you have a jump start battery you can just quickly plug in to check?
25-04-14, 09:47 AM
it usually starts first time on the button but if im being honest when i bought the bike i was worried about the battery i've priced up a new one so i'll start there.Thanks for all your advice.makes sense it being the battery as charging on the way to work then lasting 2 or 3 days at a time.
« Next Oldest | Next Newest »
