Problem with Renthal bars
May sound a bit silly, but has anyone any idea or solutions, to getting,Oxford heated grip to go over the knurled left-hand side of bars ? Seems very tight  Confusedmash Confusedmash
Many Thanks
Davie
I got a file to take off the plastic casting marks inside the grip, went on with not much bother after that...
Okay, cheers bud, will giv it a try
Many Thanks
Davie
I fitted some last year, I used hairspray squirted on the inside of the rubber and it went on fine, when it dries the hairspray acts like a glue and stops the grip moving. I have done this on many bikes over the years, hope this helps.
Are renthals any higher than standard bars as I'd like something higher / wider
(30-01-14, 09:10 AM)Paul Kent link Wrote: Are renthals any higher than standard bars as I'd like something higher / wider
Depends what style u go for as there are a few :-)
Many Thanks
Davie
Is there not a  specific type for this bike?
I don't want to have to replace cables etc
If you go higher you're most probably have to replace you brake lines.
[Image: 73337.png]
If you can live with the width, then wouldn't bar risers be an easier option to get height?
I have 25mm risers on my thou and it does make a big difference
Grips on, no probs,  little tap with a mallet  Smile Smile
Many Thanks
Davie
