ACF50 - Not Convinced?
http://f2mcltd.blogspot.co.uk/2012/01/wi...65-or.html
I meant to do this sort of test with 2 plain steel washers spray one with ACF 50 and leave the other plain and then hang them up outside but never got around to it.  Perhaps I will this weekend perhaps others would like to do a similar test and we could have FOC-U evidence.
I just leave my Fazer covered in chain lube and it doesn't seem to rust Big Grin
had actually just switched from fs365  and now glad that i have. Thought you were going to say acf50 was rubbish having just spent 15 quid on it. phew.
So what do you actually spray with it? I have some in the shed, but pink fluid puts me off spraying it.
I'd have preferred to have seen the second test carried out exactly like the first, using wire wool.
(03-01-14, 04:16 PM)hightower link Wrote: So what do you actually spray with it? I have some in the shed, but pink fluid puts me off spraying it.
From what I understand, everything! Just not the brakes basically? (discs or calipers)
washed once a week, no problems with corrosion
Just don't fancy clarting my bike up with that shit
I keep it clear of pivot points. When it is sprayed on to the swing arm any chain spray on it just dissolves which is great for wiping the swing arm clean, but I do not fancy it running into the greased pivot points and dissolving the grease.
I presume it better to buy the acf bottle which comes with the pump as opposed to the aerosol?
(04-01-14, 10:38 AM)midden link Wrote: I presume it better to buy the acf bottle which comes with the pump as opposed to the aerosol?
If that's an atomising spray, it's gotta be better than the aerosol.
I find the aerosol comes out too thick.
And im not that impressed with it, only because I thought it was going to be thinner and then form a kind of film and then dry. Its more like goo when sprayed, so I spray a bit into the lid and spot dab with a brush. Although if I ride in the wet all day long then I would wipe on with a rag.
I just spray it on a rag and then wipe the bike
I don't like morning people...or mornings...or people.
What I don't like about acf50 is that if I put on downpipes they smoke and stink until acf burns off, but at least it does the job
if it burns off it hasnt done anything has it?
It has from the point I put it on to the point I started the engine, right? Which in my case could be a week or two
Besides I think that it's only the excessive that get burnt off because even after a long run pipes feel a bit slimy, like there was still some acf left on them. I am not saying it is the best solution, all I am saying is that I have been using acf on all my bikes and never had any issues with rust (at least on those most crucial areas).
ACF50 gets my vote.
I put the acf50 in a small perfume type bottle then leave the container in boiled water for about 5 minutes then it comes out like a very fine mist
Cover entire bike with it very easily and looks fantastic - no rags required
'Test carried out by David Angel of F2 Motorcycles Ltd'
Dave Angel: Eco Warrior
