Front faring nose gold/yello
Hi does anyone know where I can get a front end nose faring gold/yellow for my fazer just dropped it on car and cracked it on left hand side  :rolleyes  Thanks Miranda
where are you from Miranda. If the damage can be fixed you can have someone weld it up.
Mine was fixed earlier this year and looks good as (once I get the decals sorted)
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways - Chardonnay in one hand - strawberries in the other - body thoroughly used up, totally worn out, and screaming - WOO HOO! What a Ride!"
you can get kits to do it yourself> Never used myself tho
Agree on the fix it option if you can
But occasionally you will see Fazers going up for breaking which might be an option (plus a respray) or you have ebay - most require spraying as well and aren't cheap - usually around £150~
Do a free UK breaker search online, there's bound to be something about.
I plastic weld and respray and I have repaired fairings on the shelf that are ready for paint. Mark @ Motorcycle Republic 07887 854614
Take it off and weld it using a soldering iron melt wrote staples into it (like paper clips) to reinforce it sand and fill it and books your aunty
Wire staples lol and bob is your aunty bloody predictive text
Quote:Take it off and weld it using a soldering iron melt wrote staples into it (like paper clips) to reinforce it sand and fill it and books your aunty
The Wurth fairing repair kit uses staples for reinforcement but as a long term plastic welder I know that the wire staples will not hold long term and the repair will split in the future, As for a Soldering iron, Seriously? for one they don't get hot enough for an affective repair which will leave the crack still there in the surface of the plastic. I have had to fix fairings where people have used a soldering iron, staples, and even parts of a coat hanger to fix it.
If your gonna get the job done, do it properly and with the right tools and materials
Ya you may be right mine has been done done it around a year ago no probs up to now but if you can afford it there's nothing like a professional job
Could you please post up the "coat hanger fix" so we can all be prepaired if we need to do ours
(10-10-13, 12:07 PM)fazersharp link Wrote: Could you please post up the "coat hanger fix" so we can all be prepaired if we need to do ours
It's a botched fix.
Ok again I should of added one of these  :lol  or this  :rollin to my post.
Too dry maybe  Smile
http://www.ebay.co.uk/itm/Yamaha-FZS600-...5d440b8ed5
search YouTube for dellboys garage its as good as you want it to be if you cant afford a pro job and can see you through untill you can afford a pro job
Quote:I have had to fix fairings where people have used a soldering iron, staples, and even parts of a coat hanger to fix it.
Quote:Could you please post up the "coat hanger fix" so we can all be prepaired if we need to do ours
Don't do it, as stated its a botch and wont hold. and then when you get a prop job done the person doing it will have to cut out your botch and start again making the repair much more expensive
