Rack
Can anyone advise me of the best rack to put on my FZS 600. I want to add some luggage carrying capacity to it
Thanks for your help  Smile
I have a rentec rack which is ok, but no topbpx etc for me. I'm lead to believe if you can afford it the givi is the way to go Smile
Renntec + topbox = no no........trust me
Having said that, if you don't want a topbox, the Renntec is fine. Easy to strap things too, even quite big bags. Doesn't spoil the look of the back of the bike either.
Hi,
Sounds like you want the following:
- Givi rack with fixing kit (nuts, bolts and spacers) for FZS 600
- Monokey plate (M3) (Monokey is rated for higher loads and speeds than the lower rated monolock, big bike rather than scooter basically)
- Any monkey compatible box (doesn't have to be Givi so long as it's Monokey compatible)
Second hand rack and plate generally go for around £50 or less on ebay. Might need sanding and painting.
If you're anywhere near Derby I think I have an M3 plate going spare you can have for free but they are only cheap anyway and generally included with the rack.
Second hand boxes can cost a lot or a little depending on condition, I picked up a nasty one for a tenner but good enough for the shopping  Wink A shiny one probably £40-£60 I guess
HTH. Andy
Givi is the best rack, forget putting a renter on its not strong enough to take a box
It was a Givi rack for me from Wemoto for me, mine's Monolock to match
the 46Ltr second hand box from ebay
Sorted    Smile
Yep, Givi rack is the best one to go for. Model you need is the 340F, which covers both square eye and fox eye models, boxes comes with slightly different bolts for each. The plate you want is the M3 monokey one. This includes the silvers bits that go on the ends of the rack arms too.
Hunt around second hand, they come up now and again, but do make sure it includes all the fitting bolts you need for your model of bike. M3 plates are more available on ebay, as these are common to many bikes. Only the 340F arms are unique to the FZS600.
Any old Monokey top box should then bolt on. Once you've got the rack fitted, just hunt around local and see what comes up cheap. I managed to pick up an old 52ltr Maxia one for £35.
I did a bit of a write up on my blog on the fitting of these racks, check it here: Givi Rack & Top Box on Fazer 600.
In fact, I've just had to replace this, as I bent the hell out of it and snapped the plate in a recent off. Sad Just came to £100 delivered from Motorcycle Planet (arms and plate). The first one came direct from an Italian ebay seller, cost me ~£65 delivered, but the strong Euro makes this less favourable now.
(01-10-13, 08:12 AM)Kentish link Wrote: Givi is the best rack, forget putting a renter on its not strong enough to take a box
Yeah, that became apparent when my top box overtook me  :groan
Good stuff. Just what I was after except for one thing. I'm after a full luggage setup. Has anyone got any advice on what to get. I know the cases well enough but it is the fixings I'm not sure about.
Any help would be greatly appreciated Smile)
There is always ChristoT's approach usiing soft paniers strapped through the seat
(01-10-13, 11:13 AM)ChristoT link Wrote: [smg id=1032]
I have seen more on a [img alt=:faz]http://foc-u.co.uk/Smileys/efocicon/faz.gif[/img] on this forum but can't remember who { need new thread - the most on a fazer }
Or, Givi do a Wingrack, it mount onto the lower part of the rear pegs, seem to remember reading somewhere you have to change the rear pegs to the later longer ones. Unsure, might be possible to make up a bracket
.jpg   wingrack.jpg (Size: 128.35 KB / Downloads: 168)
Thanks for all your help folks  Wink
I'm offskis top great Yarmouth tomorrow for the night from Kent, about 160mi with missus on the back with a tank bag and soft panniers for luggage. Loaded them up to see how my bike does so will post a message on how it goes if you want? Smile
Yeh cheers bud, remember pics too please 8)
Sure mate. No worries Smile
If you want serious hauling capability, there's always a trailer! You're allowed to tow 140kg behind a Fazer (based on a kerb weight of 210kg) - which iis only 10kg off the max allowed behind a bike (150kg) anyway. And I dout the police would take you to a weighbridge unless you were, say, towing a horsebox (with horse!!).
The Deef's apprentice
Heads up, wing rack on eBay
I have a complete givi rack set up (2nd hand) on a shelf in my workshop if anyone wants one
(01-10-13, 01:54 PM)Ebme Geek link Wrote: Or, Givi do a Wingrack, it mount onto the lower part of the rear pegs, seem to remember reading somewhere you have to change the rear pegs to the later longer ones. Unsure, might be possible to make up a bracket
Watching this now cheers.  Smile
Does anyone know if these wing racks only take specific cases or are they universal? Apparently they're no longer available new (according to the Givi website) so I don't want to splash out on something that's obsolete.
(08-10-13, 06:39 AM)Deefer666 link Wrote: I have a complete givi rack set up (2nd hand) on a shelf in my workshop if anyone wants one
PM sent
Eagles may soar, but weasels don't get sucked into jet engines...
