R&G Bar Protectors
I have a set of the datatool heated grips to fit but the bike has R&G bar end protectors, how do these come off to let me? Thought i better check before i start ripping bits off!  :lol
If its on the stock bars then its just a bolt that holds the bar end and screws into a fixed "nut" inside the bar. Just undo the bolt in the centre of the bar end and it should come off with it Smile
I unscrewed the black nylon end and theres nowt else to unscrew! Only the hole the nylon end screws into!
Just realized you are on a Fazer 1000
Are they more like this; http://www.ebay.co.uk/itm/R-G-RACING-BAR...2570033cbf
If so, then the thread is part of the bar end which should just unscrew?
AH, dead eye that makes sense, when the nylon end comes off its got 2 flats so obviously for a spanner to remove them, good man!
You're welcome Smile
I'd done a little bit of research recently as I bought new bar ends for my Renthal bars - ended up using some Rawlplugs from B&Q to attach them Wink
