Problem at high revs
Hi my fazer 600 has developed a problem at high revs, when riding normally its fine but if i go past 8k theirs a point were it stutters/bogs then overcomes it, ive cleaned the carbs, replaced plugs, air filter and coils if anyone could give me some advice on whats wrong it would be much appreciated.  Smile
Oh dear, another poor stuttering Fazer Sad As of yet, no definitive answer on this - there is a rather large 38~ page thread on this with no conclusion yet...
What air filter are you using? Wouldn't be Hi-Flo perchance?
Was it happening before you cleaned the carbs?
Check that ALL the cold start plungers are fully returning on ALL crabs and the condition of the balancing tube caps.
Later
:rolleyes :rolleyes :rolleyes
It was happening before i cleaned the carbs and i bought a genuine Yamaha filter.
(29-04-13, 01:19 PM)bignoggin link Wrote: It was happening before i cleaned the carbs and i bought a genuine Yamaha filter.
Oh okay, i had a similar problem a while back and it turned out to be a carb inlet rubber had folded in on itself when it was refitted, but as it was carb number 3 it couldn't be seen. Every time i used to give the bike a bit of welly, or overtake, it would just bog down as described.
Just a thought.......
(29-04-13, 01:30 PM)darrsi link Wrote: [quote author=bignoggin link=topic=7527.msg72508#msg72508 date=1367237987]
Yep that will do it too.  The symptoms described are pointing towards too leaner mixture.
Later
Remove the the rubber plugs on the vacuum take off points and check them for cracks, they perish and crack and may need replacing.
Other issue may be loose plug caps, remove the caps and cut about 10mm of the end of the leads and refit the caps.
Still sounds like a minor air problem to me.......
I've only just notice as well it's only started since I've had my alarm taken off by a local motorcycle shop could that have anything to do with it
Check the old problem of loose or poorly reconnected wires after removal of the alarm.
(30-04-13, 11:44 PM)bignoggin link Wrote: I've only just notice as well it's only started since I've had my alarm taken off by a local motorcycle shop could that have anything to do with it
Could always pop back and see them, and ask exactly what they plugged and unplugged, or maybe just quickly check over the bits they touched.
Make sure you haven't got a kinked fuel line anywhere, and it may even be worth changing your fuel filter for the sake of a few quid too.
Too much air can also mean not enough fuel, if you have a bit of crap in your filter you may be getting an intermittent blockage, which could be noticeable at high revs when the fuel needs to flow consistently for full effect.
any news ?  Smile
problem solved i got a mate of mine to clean the carbs properly for me, he notice that one of the main jets had some dirt in, the problem seems to be solved now and the bike still pulls like a train even with 65000 miles on the clock  Big Grin
(03-06-13, 10:50 AM)bignoggin link Wrote: problem solved i got a mate of mine to clean the carbs properly for me, he notice that one of the main jets had some dirt in, the problem seems to be solved now and the bike still pulls like a train even with 65000 miles on the clock  Big Grin
nice one BIGNOGGIN  Wink    just in time for summer  Big Grin
(03-06-13, 11:38 AM)red98 link Wrote: [quote author=bignoggin link=topic=7527.msg79464#msg79464 date=1370253007]
why do i get the feeling that was said through very gritted teeth, mate?  :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin
(03-06-13, 12:27 PM)ade the blade link Wrote: [quote author=red98 link=topic=7527.msg79470#msg79470 date=1370255898]
:lol :lol :lol .....read me like a book ,matey :lol :lol ....just glad i have the thou  Big Grin
went out on my bike the weekend and gave it some and its bogging again  Sad  a local bike shop said it could be the carbs have worn with age and because of the amount of miles my bike has done? what do other people think of this as ive ran out things it could be i think.
What about the carb rubbers themselves, they can deteriorate over time, maybe worth checking for cracking or splitting causing too much air intake.
