Performance
I, and a few other foc'cers I've spoken to, have come across slow performance and timeout of page loads on the FOC forum (I've surprisingly got it in the wee hours more often than not).  Is it possible to have a look at the logs and/or load to understand if it is performance challenged ?
I think there were a few timeouts connecting to the database too.
Soz if it's an imposition.
Cheers
Simon
Hi, thanks for the report. Last year we were having many troubles and eventually our host moved us onto a different server, which seemed to sort the issues. We use shared hosting and so perhaps the other sharers are in a different timezone and busy over(our)night, or maybe there are loads of auto processes firing off.
Would anyone who gets this please make a note of time times and stick them on here (will make for a boring thread but...) and we'll see if we can build up a pattern.
As it's shared hosting I don't have access to the logs but with enough evidence/information I can go to our hosts and they can sort it :thumbup
[Image: 151860.png]
Got one at 18:14 today.  Forgot to check the error as I was already refreshing the page (I kinda got used to pages failing to load)
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
that post took about 5 attempts,  each failing with the same response.
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@foc-u.co.uk and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
7:04am this morning:
No data received
Unable to load the web page because the server sent no data.
Here are some suggestions:
Reload this web page later.
Error 324 (net::ERR_EMPTY_RESPONSE): The server closed the connection without sending any data.
I think this could be a reason for some of the double posts that occur via tapatalk (possibly)
I'm also pretty sure these errors are due to the server being overloaded or not powerful enough.
See this too
http://foc-u.co.uk/index.php/topic,7559.0.html
Farjo, or other admins, do you know what sort of usage stats you have? Bandwidth mostly
I work a lot with hosting, curious to see if I can help out the forum with some alternative hosting Smile
(01-05-13, 11:15 AM)Dead Eye link Wrote: Farjo, or other admins, do you know what sort of usage stats you have? Bandwidth mostly
I'm glad you mentioned the bit about the bandwidth being due to helping out with hosting.  This is definitely not a bandwith issue (IMO) as the web server is responding but falling down a bit further up the architecture (CPU constrained for the 404's and possibly 324's or possibly memory for the database connection resulting in the database/app/pool falling over and restarting)
tbh I don't do web server debugging but I'm relatively confident in my guesses.
ooooooh.  A good bloke to know for hosting then :-)  :lol Big Grin
Failed to connect to forum. Problems persists contact yada yada.
21.39
It was doing it last night as well right up til about midnight when I crashed. O  tapatalk
Been fine during the day.
Threads are having the loading swirl for ages as well. Need to back out and try again. Sometimes takes 2 or 3 attempts
Smell ones mother. Yaas!
Connection ProblemsSorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
Error Code 500
In my experience usually this is a web server configuration issue
@Simon - Reason I asked about bandwidth is to determine if I could offer something suitable IF the admins wanted to take me up on my offer. It was a long shot as I doubt they would want to move but it was worth a shot...
(02-05-13, 07:47 PM)Dead Eye link Wrote: 19:45
Error Code 500
@Deadeye You're a nice guy trying to help  Big Grin
I suspect the 500 is just before the virtual server falls in a heap and restarts (iirc 500 is just something is foobarred but I can't report specifically what it is rather than specifically misconfiguration although that is definitely an option).  The forum runs fine most of the time, so I guess the 500 is just appearing just before or after it goes titsup.com.  I wouldn't have thought a hosting company would have mis-configured apache/mysql/whatever, but it wouldn't be the first time I was wrong (I would hope for their sake they know their business better than that).
I don't know which of the UKhost4u packages they have signed up for but it'd be interesting to know.  I suspect the back up jobs run in the wee hours and suck quite a bit of CPU and memory away from the hosting.
It's all guess work until one of the admins hits the support people with a stick.
You are quite correct regarding the 500 errors - what exactly do you do for a living? You have a fair knowledge of these things Wink But yes, generically, 500 is the server threw an unrecoverable error somewhere along the line. The hosting I deal with currently doesn't use VM's so less of an issue of it falling over
Truth be told, I hadn't looked at the current hosting platform that the forum runs on so you have done your research Tongue As for backups, I'm reserved on that. No way to know for certain as to whether they are running any at all and even then an incremental backup (which is what I would expect) isn't hugely intensive.
I've just had a 500 error trying to look at this thread...!!
getting a bit frustrating now took me for ever to post a reply on my headlight thead  and I got this and lost my post !
then it didn't look like it was going to let me post this !
Got the same thing at 12:20, a 500 internal server error:
EDIT: This was trying to send a PM.
Internal Server Error The server encountered an internal error or misconfiguration and was unable to complete your request.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
The Deef's apprentice
