Parts list
Does any have the (or link to) parts list for the Mk1 Fazer (I used to have a PDF, but can't find it now)?
I have used here :
    http://www.yamahamotorcyclespares.co.uk/...4&m=YAMAHA FZS600 FAZER&uID=0
click on a part, and it gives the yamaha no under parts detail
I need more detail.
I need the part numbers for the o-ring on the starter motor and the brushes + any other consumables
Under downloads
then manuals
Then FZS600 Fazer
http://foc-u.co.uk/index.php?action=down...file&id=13
thanks - that's the one.
When I did my starter recently,  I got this
http://www.ebay.co.uk/itm/271162969101?s...572wt_1061
came with all bits needed, I did not use the rear bush as mine seemed fine, or the one in the nose as mine was a roller bearing and seemed fine.  Cost me £32.93 at my door came pretty quick aswell.
Check out the price of the yam gaskets 11H-818440000  wemoto  £ 15.22 ex vat !!!    each ??
                              Brush holder assy 3HE-818400000              £ 39-96  - " -
                                    other o-ring                                        3.49
I've decided to get a second hand one from Fazer Spares (I only work about 3 miles from them). The ebay one is interesting though. Also interesting to note he accepts no returns - an illegal position.
Might be worth checking that the brushes are not sticking, one of mine was and I think a clean would have sorted it, but I had already got the kit  :rolleyes
Problem is you need the o-ring and gasket if you take the motor out.
If I had more time I would, but for simplicities sake I'll just replace it. I can look at repairing and selling the old motor if need be.
