Footpump Reccomendations
Can anyone reccomend a decent footpump that works on motorcycle tyres without breaking after two weeks/leaking/letting air out when the clip is removed/falling over when you pump it etc. Me and my brother have been through 3 footpumps in as many months and have just binned a useless Halfords one. Does anyone use one of those stirrup type pumps?
Only caveat is, I don't really want to spend more than £25
this one is excellent
http://www.nippynormans.com/products/pum...un-8600250
its £35 on this site but I've seen it for £30...from a mountainbike online shop?? cant remember which one though sorry.
I use my Topeak Joe Blow track pump for the bicycle, motorbike and car.
Best not rely on the gauge though, I've got a digital gauge for that sort of thing.
I've got a Joe Blow as well
thou shalt not kick
If you are blowing bicycle tyres up to 120 psi, great!
If you are trying to work out either 32 or 36 psi in a front trye, need a better gauge.
Oh no, the great tyre pressure debate again!
(36/40 at the mo,,,,)
keep an eye out in LIDL/Aldi.
I bought one for £35 which is a jump starter, recharger for USB connections, 2 cigarette connections chargers and a compressor.
only down side is that the dial isnt calibrated so still need to use a seperate calibrated pressure gauge
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways - Chardonnay in one hand - strawberries in the other - body thoroughly used up, totally worn out, and screaming - WOO HOO! What a Ride!"
I bought one like  Lazarus did from Godfrey DIY, The internal battery died after six months, but it was good while it lasted...
I also got fed up of footpumps not lasting so brought one of these from halfrauds for £20
http://www.halfords.com/webapp/wcs/store...yId_255241
the pump action has lasted ok but the hose as perished  Sad , now looking out for a cheap pump to swap the hose over. I dont trust the bulit guage either and use a separate pressure gauge .
i have gone through a few foot pumps over the years... the current michilin (single barrel) pump that takes up garage shelf space has not only outlasted every other by some margin thus far but also the built in gauge agrees with my trustworthy long term hand-held pressure gauge! so much so that i don't even bother checking my van tyre pressures with the hand gauge i just set them on the michilin pump.
the only fault with it is that one of the plastic lock down tabs broke off it's tethering strap. it was a bit flimsy.
is it clean enough?
