headlight mod
hi everyone  i seen a link on how to do mod on headlight  as both lights come on can anyone pop a link on how to wire this set up or if you have  a better suggestion  i will take on board  thanks all
Click on "Articles", select "FZS600" and the top item listed is the one you want. Smile
:thumbup cheers fazerider  i knew i had seen it posted before  Wink
Quote:a better suggestion
Buy yourself an H4 HID kit from China for about £25.
Wire it so its your only headlight* and remove the bulb from the H1 side.
Put it back to normal once a year for MOT time.
* It waggles up and down for dip/main beam and the single capsule stays lit all the time.
* You need to adjust the headlight aim to avoid blinding oncoming traffic.
if you want a hid kit drop me a line as i have just removed one due to a total headlight change
follow me and ile show you were to crash
http://foc-u.co.uk/index.php/topic,484.m...ml#msg2583
Keep me posted on what upgrade you do. I have wired the two up as per the other thread and is was quite easy. I am interested on how the H4 HID kits works. Is there a thread on how to do that ?
if you have allready done the h4 heigh/low mod a hid kit virtually bolts straight on
