18-04-12, 12:16 PM
Is there anybody in SE London/Kent that would be able to replace my front wheel bearings if I delivered the wheel and the bearings?
Front Wheel Bearings
18-04-12, 12:16 PM
18-04-12, 02:56 PM
Yes, mate ... you! Seriously, this is well within your capabilities.
![]() Unlike the rear wheel bearings, the fronts are easy to get out. Likewise, fitting the new ones is a breeze. No special tools required. A long drift or old screwdriver and mallet will take care of the removal. Tap in the new ones with a socket the same size as the outer race. Doddle. By the time you've taken the wheel to someone else, you could have changed the bearings and refitted it yourself.
18-04-12, 05:07 PM
dont forget to put the spacer back in and dont ask me why i should remind you
18-04-12, 05:10 PM
Hi Mike, I thought they would be similar to the rears and the guy had to weld a piece on the outer race to give him something to knock out with the drift. Putting the new ones in he used a masive big hammer, if he had missed the bearing he would have broke the wheel in half. lol
I'll dig out the bearings and give it a try. On your head be it!!!!! Thanks Luke. I am going to give it a try.
18-04-12, 05:43 PM
Hi mate
![]() I assume you've removed bearings before but if you want any more information, drop me a line. Cheers! Mike
18-04-12, 07:47 PM
Thanks Mike, PM left
26-04-12, 03:36 PM
OK, wheel bearings replaced, easy, easy easy!!!! Thing is, the noise I suspected would be noisey wheel bearings (bike has covered nearly 60k miles) is still there :'(
It must be tyre noise. The front doesn't feel any different. I know it must be because its new. At least its done now.
26-04-12, 05:05 PM
Well done, mate.
26-04-12, 07:08 PM
and thank you Mike for your invaluable help as usual
« Next Oldest | Next Newest »
