Ignition advancer
I've got a +4 degree advancer on my full monty gen 1 fazer. There isn't that much of a difference compared to the standard advancer, but i also have a stock fazer with only a fairly quite race can (venom) fitted and was wondering if an ignition advancer would improve it. I know the best thing to do is fit an ivans kit, but i've already got one of those!  8) and just wanted a fairly cheap way to get crisper throttle response and also remove the very slight surging you get with the stock bike. Cheers in advance - Get it! :rollin
Hi Nick
Do Eskort's advancer mod:  http://www.yamahafz1oa.com/eskortsadvancermod.shtml
I've done it on mine and it's the cheapest way to get an advancer.
See what you did there ... Wink
Thanks mike, that's a definite option. I can get a factory pro on fleabay from America for £50 inc postage. Do they make a good improvement to a standard gen1?
Yes, still worth doing.  Don't drop that kind of cash into one, though.  Go the DIY route - it's so easy. Smile
Sorry bout the thread hijack here, but I thought Ivan strongly advised against advancers on these with 'STOCK' compression ?
Installation time for this kit is just 15 minutes more than any other kit.
See the review of our Slip-on kit in :
Motorcyclist magazine - January 2003
Motorcycle Consumer News - July, August ?? 2004
IMPORTANT NOTE:
Remember!
This is an R1 motor. Ignition advancers are notrecommended unless you have significantly raised the compression!
See our dyno test in the FZ-1 comparisons section below....
*For information regarding the FZ-1 Engine Kits, please contact Ivan directly at:
<blockquote> <blockquote> Ivan's Rockland County Motorcycle
175 N. RT 9W Unit #1
Congers, NY, 10920
845-268-1212
Shop Hours:
Mon - Fri 10am-6pm
Sat 10am-2pm Eastern Time</blockquote></blockquote>
He does, true but in practice it works well in the rev band where most of us ride.  The benefits are most noticeable sub-4k rpm and it doesn't increase vibes until well up the tacho scale, by which time there's plenty of other things buzzin' away as well. Smile
I agree with mike. The bike is definitely better under 5k, but  i haven't noticed any extra vibes. I remember looking at dyno graphs a few years ago which showed improvements low down, slight improvement midrange and at  10'000 revs + it was down about 1-2 hp. I prefer driveability to outright power.
O! O.K Mike thanks for that. Looks like I will have to take a file to the ignition rotor the next time I get a spare mo.
Top effort, thank you very much  Smile
