Repairable?
Hi,
My Chain snapped on my Fazer, Luckily at slow speed ~20mph, Not sure why.. Chain was lubed (Scotoiler) and adjusted regulary...
Anyways, the damage is a snapped Clutch pushrod/Actuator shaft... but my main concern is the hole which the shaft goes through..  The Shaft has made a nice oblong shape out of what was once a nice round hole. Hopefully the pictures below show what i mean.
[Image: 2012-03-04_19-27-00.jpg][/IMG]
[Image: 2012-03-04_19-26-28.jpg]
Please can one of you experts tell me if the hole is acutally part of the lowercasings, and I have really screwed the pooch, and a new engine/casing is required.. or.. is this a bush/insert that i can replace.
I am kinda thinking its the casings, but.. ya never know...
Thanks in advance
Chris
I'm fairly certain that it's a casing that is FUBARed  Sad . But there's not much sideways force on the pushrod ( outherwise it wouldn't be called a pushrod).
It might be repairable with some quick metal type stuff or possibly some very careful in-situ welding.
But at the end of the day you'll eventually want to get rid of the bike and you couldn't really sell it with a bodged repair.
Hope it all turns out OK though .... Baz  Smile
what happened to the oil seal
Its possible to repair it but it's a lot of work to do it properly and get a lasting repair, engine removal, splitting/stripping hole either plugged/welded and re-drilled this requires machining just not worth all the effort and expense.
You could try bodging but it's very likely going to fail in short order, sadly  Sad  you probably better off swapping the whole engine for another and selling yours for spares.
As for why it snapped could be a a few things out of alignment, too loose/tight, loose front sprocket, wrong size/type or poor quality (fakes) chain/sprockets or just a fluke and something got flung in there and snapped it
Later
Writing off the whole engine for such a tiny bit of damage is a bit premature. As Baz says, the sideways forces on the rod are minimal.. why not fit a fresh seal and pushrod and see how the clutch feels? If it still operates OK then I'd be happy to carry on using it.
Yep! Fazerider is correct.NEVER write off an engine until you've exhausted every possibility.
Unsure whether a new seal and pushrod would work,but you have nothing to lose. except a few quid.
Do as he says and keep everything crossed.
I have abottom end lying doing nowt so if you need the casing let me know
The Frying Scotsman
I had the same happen to me.  Luckily I only had to replace the pushrod, pushrod seal and the front sprocket cover.  Could be many reasons why the chain failed.  Always check your chain for kinks and sags when checking the tension.  I always lube using SAE90 gear oil. I've been using wilkinsons stuff for about 20K now and used it across 2 chains. Pretty good stuff!
Thanks Guys, I guess i will have to strip it down anyways to get to the broken part of the pushrod.. I am assuming, removing the entire clutch assembly will allow me to get the broken bit out.
Not too sure on just replacing the oil seal/pushrod, although it may be an option so will look to try that first.
it does seem like a waste of an engine, just for a small hole.. the engine has around 55000 miles on it, but still pulls strong.. (or should i say did pull strong  Sad )
Its was the wifes bike, and as she is a shortarse, is limited to what height bikes she can ride... and she loves it... (or did until i Broke it).. so it will be getting repaired, one way or another.
Cheers
Chris
You might be able to pull the pushrod out without pulling the clutch cover off. If you can find a powerful magnet (such as one from a defunct hard disk drive) and touch it to a steel rod or crosshead screwdriver to extend the field and poke that in the hole it may be enough to tug the remains of the pushrod out, especially if you have the bike on the sidestand.
It depends on how clean the break is... if the end is too bent it won't work, but with luck it'll save you a gasket and some time.
Thanks Fazerider,  I wouldnt have thought about trying that.. Will give that a go and see if i can get it out without removing the clutch.
Cheers
Chris
To remove the push rod get a 6 inch nail and clean the head of it with acetone or nail varnish remover,put some of the nail varnish remove onto a cloth and then clean the end of the push rod,put a drop of super glue onto the head of the nail push onto the the end of the pushrod and draw it out,  bobs your dads brother and fanny is your mothers sister,jobs jobbed,yes it does work...
ive a spare pushrod for a thunder cat  which i believe is the same
follow me and ile show you were to crash
http://foc-u.co.uk/index.php/topic,484.m...ml#msg2583
