Carb caps removal???
Any tips for getting the rubber caps off the carbs to allow a carb balance to be done? No, I haven't got any of those long reach plier things with a bent nose!! .....Hoping the answer won't be 'Get some of those long reach plier things with a bent nose!'
Or
you can use a long flat head screwdriver as well but it is fiddly
i dont have that problem anymore as i did the cross-over mod and thats realy easy to remove.
[Image: 82304.png]
The little clamps don't take much compressing.  You should be able to get at 1 & 4 with your fingers.  Possibly #2 as well, depending on the size of your hands.
For #3, use the flat-blade 'driver but put a magnetic extension tool on the clamp to stop the cap flying off and dropping where you can't see/reach it. Smile
having got the caps off via whatever means you choose , putting them back on might not be so easy ? might i suggest a set of those long nose plier things with a bent nose !  :thumbup
Thanks gents...seems I need some of those long reach plier things with......... 8)
