Increasing low range
Anyways to increase it? currently my bikes got a sports exhaust, thinking of buying a standard in a hope it will increase>?
Good quality end can and a K & N filter will clean things up and make the bike fill crisper other than playing around with gearing which to some extent will rob the top end there's nothing else.
Fazers don't normally suffer from lack of low end power compared to other 600's if anything they are stronger, make sure all is as it should be.  If you still want more you may have to look elsewhere say a twin.
Later
I would say returning to standard can will improve things . I have fitted both open cans and baffled to my 600's in both cases I have lost low down responce,  KN filters are good
Please post after replacement .
(26-12-11, 06:19 PM)bwizz link Wrote: I would say returning to standard can will improve things . I have fitted both open cans and baffled to my 600's in both cases I have lost low down responce,  KN filters are good
By K&N will this suffice? http://www.ebay.co.uk/itm/Yamaha-FZS600-...2eb9b523ce
or a free running one to each carb
yep that' the one
follow me and ile show you were to crash
http://foc-u.co.uk/index.php/topic,484.m...ml#msg2583
Fitted K&N made quite a difference  :eek much better low/mid range and sounds alot better too .
